Packet Tracer NAT ASA
JS Ouellet
HI,
I configured a topology with L3 SVI
10.10.10.0/24  PCs
10.10.20.0/24  PCs
10.10.30.0/24  PCs
192.168.5.0/24  DHCP server
192.168.66.0/24 ASA inside
I use eigrp to distribute routes.
Everything works as expected  but not the firewall nat.
I use autonat
object network OBJ_GENERIC_ALL
subnet 0.0.0.0 0.0.0.0
nat (inside,outside) dynamic interface
I checked with simulation mode icmp pdu, the firewall nat only the traffic from is inside network 192.168.66.0.
If I try to ping with a node in an other network, the source address pass through the firewall unnated.
The enable password on all devices is: toto
What is wrong with my config?
JS
10 Replies 10
Francesco Molino
You want to meet your 5 internal subnets to your asa outside interface when communicating with external services? Eigrp is done between your switch and asa?
Can you share your asa config please?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Muhammad Awais Khan
your configuration looks good, can you share your complete config ?
BarinderGhuman
I can see that you have configured dynamic nat, it works only if your traffic initiates from Inside. It dynamically may the source of outgoing packet and keep a session session for the return traffic.
You need to either use port-map if you want to use internal network using Ada's outside IP address or configure static NAT.
Cheers,
Barinder Singh Ghuman
Cheers,
if possible. post the zipped Packet Tracer project (.pkt) file...
HI,
There is my packet tracer lab file. The enable password is: toto. I had success with NAT using a router dynamic NAT with an ip pool. I still don't know how to configure the ASA correctly.
The firewall config:
ASA Version 9.6(1)
hostname ASA5506
domain-name test.com
enable password j/LunF5bRjBb71wO encrypted
names
interface GigabitEthernet1/1
nameif inside
security-level 100
ip address 192.168.66.1 255.255.255.0
interface GigabitEthernet1/2
nameif outside
security-level 0
ip address 24.24.24.226 255.255.255.252
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
route outside 0.0.0.0 0.0.0.0 24.24.24.225 1
access-list inside_to_internet extended permit tcp any any
access-list inside_to_internet extended permit icmp any any
access-group inside_to_internet in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
router eigrp 1
eigrp router-id 192.168.66.1
network 192.168.0.0 0.0.255.255
ASA5506#
Does the bug is documented somewhere in Cisco bug lists? Where can I reach that, I will review before posting if I get another odd behavior.
Thanks all for replies.
actually, I did some testing, and it still does not work. The 'proxy-arp' only seems to work if all subnets belong to the same supernet. You have 192.168 and 10 networks, so the 'solution' does not work.
That said, is this a lab test for a production environment, or an assignment within Packet Tracer ? If it is the first, I would not worry about it, since the configuration will work fine on a real device...
It didn't worked either for me.
I use Packet Tracer now to refresh my knowledge, it's a lot of fun. I use a router now in my lab to dynamic NAT with an ip pool, it works fine.
Thanks for your support.
JS
Packet Tracer can be useful, but it does not have full featured IOS or ASA OS versions, but rather a subset of commands available. So things sometimes might not work as expected...
