Packet tracer OSPF into BGP setup help/suggestions
thom784e
Hello i currently have this small setup. i have configured ip routing on the L3's and want to use those as gateways on the PC's and then have them send the data to the router.
Right now the PC's send their data to the HSRP standby IP i've setup between the L3 switches.
How should i configure the switches to be able to have a redundant link to the router? do i add more ports to the router and do a port channel between the router and both the L3 switches and then set an IP on the port channel and do the
ip default-gateway (ip of port channel 5 interface on router)
on one L3-01 and do the same but with a different port channel and IP on L3-02?
i will be doing a copy paste setup next to this aswell and plan on trying to do a BGP setup to allow PC1 to access some stuff on the other OSPF Area but i haven't worked with BGP before so if you guys have a good tutorial you could recommend i would appriciate that
if you need any other info to be able to help i will do my best to provide it asap
thanks for your time
two solution
1- use Dual HSRP and static route toward HSRP VIP
R1#show run
R1#show running-config
Building configuration...
(C7200-ADVIPSERVICESK9-M), Version 15.2(4)S5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 20-Feb-14 06:51 by prod_rel_team
Current configuration : 1746 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
track 1 interface FastEthernet1/1 line-protocol
track 2 interface FastEthernet0/0 line-protocol
ip address 10.0.0.1 255.255.255.0
standby 10 ip 10.0.0.10
standby 10 priority 110
standby 10 preempt
standby 10 track 1 decrement 30
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.1 255.255.255.0
standby 20 ip 20.0.0.20
standby 20 priority 110
standby 20 preempt
standby 20 track 2 decrement 30
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
serial restart-delay 0
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 30.0.0.0 255.255.255.0 20.0.0.3
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#show run
R2#show running-config
Current configuration : 1554 bytes
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 10.0.0.2 255.255.255.0
standby 10 priority 90
standby 10 preempt
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.2 255.255.255.0
standby 20 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#show run
R3#show running-config
Current configuration : 1441 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 30.0.0.3 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.3 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
no ip http server
ip route 10.0.0.0 255.255.255.0 20.0.0.20
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
or
2- use EEM with HSRP
R3#
R3#
R3#show run
Current configuration : 2339 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
track 10 ip sla 10 reachability
interface Loopback0
ip address 3.3.3.3 255.255.255.255
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip address 200.0.0.3 255.255.255.0
ip ospf cost 100
speed auto
duplex auto
interface Serial3/0
ip address 100.0.0.3 255.255.255.0
ip ospf cost 1000
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
ip ospf cost 100
no ip address
shutdown
negotiation auto
router ospf 100
network 3.3.3.3 0.0.0.0 area 0
network 100.0.0.0 0.0.0.255 area 0
network 200.0.0.0 0.0.0.255 area 0
no ip http server
ip route 10.0.0.2 255.255.255.255 FastEthernet2/1 permanent
ip sla 10
icmp-echo 10.0.0.2 source-interface FastEthernet2/1
ip sla schedule 10 life forever start-time now
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
event manager applet HSRP-VIP1
event track 10 state down
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "router ospf 100"
action 1.3 cli command "no net 200.0.0.0 0.0.0.255 area 0"
action 1.4 cli command "exit"
event manager applet HSRP-VIP2
event track 10 state up
action 1.3 cli command "net 200.0.0.0 0.0.0.255 area 0"
end
otherwise the router always send traffic toward the one l3SW even if it not active
MHM
7 Replies 7
IGP with hsrp is need alot of work
Instead
In router config static route toward VIP of HSRP
In each l3SW config defualt route toward router
MHM
so i should set a static route that anything that needs to go to vlan 1 gets sent to the vlan 1 HSRP IP
(ip route x.x.x.xip of other network on the other bgp x.x.x.xhsrp ip
so set an ip on the 2 interfaces on the router, and configure both L3 switches to point to both? or just the one connected.
let lab it and send to you the exact steps
MHM
can you post your (zipped) Packet Tracer project (.pkt) file ?
Are you using HSRP standby tracking ?
there you go
yes i have HSRP standby on the L3 switches
two solution
R1#show run
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
standby 10 preempt
duplex full
no ip address
shutdown
speed auto
duplex auto
standby 20 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#show run
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
standby 10 preempt
duplex full
no ip address
shutdown
speed auto
duplex auto
standby 20 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#show run
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
duplex full
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
no ip address
shutdown
negotiation auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
or
R3#
R3#
R3#show run
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
ip ospf cost 100
speed auto
duplex auto
interface Serial3/0
ip ospf cost 1000
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
ip ospf cost 100
no ip address
shutdown
negotiation auto
router ospf 100
no ip http server
ip sla 10
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
MHM
thanks a lot, i think i can use some of this to edit my setup.
