Packet Tracer: Router swaps Destination IP address with Source IP address
YJJcoolcool
When I try to access the webserver from PC7 (see screenshot), I am given a "server reset connection" error. Upon checking the packet, I observed that the router RTR-1 is swapping the Destination IP address with the Souce IP address. Is there a way to fix this via configuration? And why is it happening?
you made a simple typo.
The serial interface Serial0/1/0 of your router RTR-1 and the web server have the same IP address:
description Link to Internet
ip address 203.0.113.100 255.255.255.0
If you change the IP address of the web server to 203.0.113.101, the connection works. Attached the revised file.
5 Replies 5
balaji.bandi
we do not have any visibility of the router config - so suggest to read this thread :
https://community.cisco.com/t5/routing/packet-tracer-how-i-fix-quot-server-reset-connection-quot-error/td-p/4070963
BB
post the zipped Packet Tracer project (.pkt) file...
Martin L
you can attach PT file in a zip format here or copy and paste router config
Regards, ML
**Please Rate All Helpful Responses **
Hi, attached is the zipped packet tracer.
Here is the router config when I run the show run command (removed ! to reduce length):
Current configuration : 907 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet0/0/0
description Link to MSW-1
ip address 203.0.111.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1/0
ip route 0.0.0.0 0.0.0.0 203.0.111.2
ip route 203.0.113.0 255.255.255.0 209.165.201.1
ip flow-export version 9
line con 0
login
line aux 0
line vty 0 4
no login
end
