Packet tracer scenario help
So I’m pretty new to packet Tracer and I’ve been given the scenario which I need to complete and I need your help because I don’t really know how to do this. The router Central, ISP cluster, and the Web server are completely configured. You must create a new IPv4 addressing scheme that will accommodate 4 subnets using the 192.168.0.0/24 network. The IT department requires 25 hosts. The Sales department needs 50 hosts. The subnet for the rest of the staff requires 100 hosts. A Guest subnet will be added in the future to accommodate 25 hosts. You must also finish the basic security settings and interface configurations on R1. Then, you will configure the SVI interface and basic security settings on switches S1, S2, and S3.
Not sure what the firewalling requirements are, but it should be easy once you have the addresses configured (first part). If I were doing it, it'd look like this:
Staff Network:  192.168.0.0/25 (192.168.0.0 255.255.255.128) to accommodate 126 hosts (1 - 126, 127 Broadcast).
Sales network:  192.168.0.128/26 (192.168.0.128 255.255.255.192) to accommodate 62 hosts (129 - 190, 191 Broadcast).
IT network:        192.168.0.192/27 (192.168.0.192 255.255.255.224) to accommodate 30 hosts (193 - 222, 223 broadcast).
Guest Network:  192.168.0.224/27 (192.168.0.224 255.255.255.224) to accommodate 30 hosts (225 - 254, 255 broadcast).
Pretty sure that works. Still waking up.
Martin L
You can attach your work here as PT file and we can fix it or make suggestions
