Redistribute static route issue
elpablito
I cannot understand why, while static route can be redistributed to EIGRP over the network, I cannot ping from directly connected interface from R1 to R5, just from Loopback.
R1 output:
R1#sh ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Ethernet0/0
      1.0.0.0/32 is subnetted, 1 subnets
C        1.1.1.1 is directly connected, Loopback1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, Ethernet0/0
L        192.168.1.1/32 is directly connected, Ethernet0/0
R1#ping 5.5.5.5
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R1#ping 5.5.5.5 source loopback 1 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds: Packet sent with a source address of 1.1.1.1 !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
R2 output:
R2#sh ip route
Gateway of last resort is not set
S        1.1.1.1 [1/0] via 192.168.1.1
      2.0.0.0/32 is subnetted, 1 subnets
C        2.2.2.2 is directly connected, Loopback1
      3.0.0.0/32 is subnetted, 1 subnets
D        3.3.3.3 [90/409600] via 172.16.1.2, 00:18:08, Ethernet0/1
      4.0.0.0/32 is subnetted, 1 subnets
D        4.4.4.4 [90/435200] via 172.16.1.2, 00:18:08, Ethernet0/1
      5.0.0.0/32 is subnetted, 1 subnets
D EX     5.5.5.5 [170/332800] via 172.16.1.2, 00:15:30, Ethernet0/1
      10.0.0.0/24 is subnetted, 1 subnets
D        10.10.1.0 [90/307200] via 172.16.1.2, 00:18:08, Ethernet0/1
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.1.0/24 is directly connected, Ethernet0/1
L        172.16.1.1/32 is directly connected, Ethernet0/1
L        192.168.1.2/32 is directly connected, Ethernet0/0
Hello
Show the route table for R3 ,4,5, and make sure rtrs physical interface subnets are being correctly advertised in eigrp without auto-summerization enabled
router eigrp xx
no auto-summary
Kind Regards
Paul
Hello
router eigrp xx
no auto-summary
Kind Regards
Paul
Thanks for quick response, so yes I missed adding statement about local subnets to EIGRP, added this with no auto-summary and it works like charm!
R2(config-router)#do sh run | s rout
router eigrp 1
 network 2.2.2.2 0.0.0.0
 network 10.10.1.0 0.0.0.255
 network 172.16.1.0 0.0.0.255
 network 192.168.1.0 0.0.0.255
 redistribute static
 no auto-summary
ip route 1.1.1.1 255.255.255.255 192.168.1.1
Jon Marshall
I am not following where the static route part comes into this ?
From what you have posted Paul is right you just need to advertise the interconnecting subnets into EIGRP but that doesn't seem to be what your question is about.
Jon
