Packet Tracer - WAN config router to router using Serial DCE?
amnbhrmistic
Here's my network scheme in Packet Tracer:
http://i.imgur.com/RKrjB.jpg
How do I do the routing in CLI to connect those three routers?
Note that the routers are in different cities. Any videos or tutorials I can follow?
Thanks.
cadet alain
You can use static routing or any IGP like RIPv2,EIGRP or OSPF.
you will find many tutorials on routing on the internet.
Regards.
Alain.
johnlloyd_13
Level 9
Level 9
You can start by using RIP for networks with less than 15 hops.
http://www.trainsignal.com/blog/cisco-how-to-configure-rip-1
Here's a good link for training videos:
http://www.cbtnuggets.com
