packets drop (QoS)
ohassairi
Level 5
Level 5
Hello
to garantee a bw for oracle application i configured this in HQ (oracle server is there)
class-map All-Traffic
match any
exit
policy-map G01-Policy
class All-Traffic
   shape  average 16000000 (the wan speed is 16Mbps)
   service-policy outbound-Policy
exit
access-list 195 permit ip 200.0.0.0 0.255.255.255 any
class-map match-all DB_traffic
match access-group 195
exit
policy-map outbound-policy
class DB_traffic
    bandwidth 4096 (i want to garantee 4Mbps for DB)
exit
class class-default
    fair-queue
exit
exit
interface GigabitEthernet0/1
service-policy output G01-Policy
however i noted that:
-1 have 2 default classes? is this normal?
2- many packets are dropped in the 1st default class (see below) Can you explain why? will this make other applications slow?
core-router-labor#sho policy-map interface gigabitEthernet 0/1
GigabitEthernet0/1
  Service-policy output: G01-Policy
    Class-map: All-Traffic (match-all)
      30803364 packets, 9676560228 bytes
      30 second offered rate 4737000 bps, drop rate 10000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/26970/0
      (pkts output/bytes output) 30776380/9654641198
      shape (average) cir 16000000, bc 64000, be 64000
      target shape rate 16000000
      Service-policy : outbound-policy
        Class-map: DB_traffic (match-all)
          4083861 packets, 800694517 bytes
          30 second offered rate 103000 bps, drop rate 0 bps
          Match: access-group 195
          Queueing
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 4083861/800694517
          bandwidth 4096 kbps
        Class-map: class-default (match-any)
          26719489 packets, 8875853172 bytes
          30 second offered rate 4636000 bps, drop rate 10000 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/26970/0/26970
          (pkts output/bytes output) 26692519/8853946681
          Fair-queue: per-flow queue limit 16
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: any
      (pkts output/bytes output) 12/12431
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
1) Yes it is.  CBWFQ always has a default class.
NB: if you want to match all packets, you could have done:
class class-default
2) Likely because queue depth isn't deep enough to support 16 Mbps.  For a single TCP flow to obtain optimal performance, as a rough rule of thumb, egress queue should be sized to about half of BDP (bandwidth delay product).
QoS features vary per platform and IOS version, but try something like:
class DB_traffic
class class-default
    fair-queue
queue-limit 1024 (not 100% positive this is correct syntax)
Adjust as necessary.
Joseph W. Doherty
Disclaimer
Posting
class class-default
class DB_traffic
class class-default
    fair-queue
