packets loss in the QoS queue in ISR4431
jack lee
Hi all, When we replace cisco 3900 with ISR4431,there are packets loss in the QoS queue. While it is equal to the total output drops. G0/0/0 is the WAN interface. Whether there is a problem with configuration? What is the cause of the loss of packets? The attachment is the collected information. Thank you ! cn-bap-qingd-ce-03#sh interfaces GigabitEthernet0/0/0 is up, line protocol is up Hardware is ISR4431-X-4x1GE, address is 00be.7511.f230 (bia 00be.7511.f230) Description: ***3284_50M_WAN VRF Bosch-CN NC1 PE *** Internet address is 15.15.9.150/30 MTU 1600 bytes, BW 51200 Kbit/sec, DLY 10 usec, reliability 255/255, txload 25/255, rxload 28/255 Encapsulation ARPA, loopback not set Keepalive not supported Full Duplex, 1000Mbps, link type is auto, media type is RJ45 output flow-control is off, input flow-control is off ARP type: ARPA, ARP Timeout 04:00:00 Last input 03:06:39, output 00:00:01, output hang never Last clearing of "show interface" counters 02:41:29 Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 1670 Queueing strategy: Class-based queueing Output queue: 0/40 (size/max) 30 second input rate 5772000 bits/sec, 1358 packets/sec 30 second output rate 5022000 bits/sec, 1309 packets/sec 10348795 packets input, 5304613927 bytes, 0 no buffer Received 3133 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 19362 multicast, 0 pause input 9713439 packets output, 3102017544 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out. cn-bap-qingd-ce-03# sh policy-map int GigabitEthernet0/0/0 Service-policy input: QOS_VRF_CN1_CN2_in Class-map: QOS_Class_Voice_PRE_in (match-any) 696289 packets, 162448479 bytes 30 second offered rate 177000 bps, drop rate 0000 bps Match: access-group name QOS_Voice_PRE_in QoS Set ip dscp ef Marker statistics: Disabled Class-map: QOS_Class_Callsigna_Business_PRE_in (match-any) 243557 packets, 50355659 bytes 30 second offered rate 15000 bps, drop rate 0000 bps Match: access-group name QOS_Callsigna_PRE_in Match: access-group name QOS_Business_PRE_in QoS Set ip dscp af31 Marker statistics: Disabled Class-map: QOS_Class_Besteffort_PRE_in (match-all) 9425162 packets, 5091892564 bytes 30 second offered rate 5059000 bps, drop rate 0000 bps Match: access-group name QOS_Besteffort_PRE_in QoS Set ip dscp default Marker statistics: Disabled Class-map: QOS_Class_Video_PRE_in (match-all) 98 packets, 17405 bytes 30 second offered rate 0000 bps, drop rate 0000 bps Match: access-group name QOS_Video_PRE_in QoS Set ip dscp cs4 Marker statistics: Disabled Class-map: class-default (match-any) 20395 packets, 1251105 bytes 30 second offered rate 1000 bps, drop rate 0000 bps Match: any Service-policy output: QOS_VRF_CN1_out.Parent Class-map: class-default (match-any) 9727959 packets, 3098336991 bytes 30 second offered rate 4550000 bps, drop rate 2000 bps Match: any Queueing queue limit 200 packets (queue depth/total drops/no-buffer drops) 0/1670/0 (pkts output/bytes output) 9726109/3096382510 shape (average) cir 51200000, bc 204800, be 204800 target shape rate 51200000 Service-policy : QOS_VRF_CN1_CN2_out.Child Class-map: QOS_Class_Voice_DSCP_out (match-any) 369923 packets, 75334805 bytes 30 second offered rate 143000 bps, drop rate 0000 bps Match: access-group name QOS_Voice_DSCP_out QoS Set ip precedence 5 Marker statistics: Disabled police: cir 20 %, bc 1000 , be 1000 cir 10240000 bps, bc 1280000 bytes, be 1280000 bytes conformed 369923 packets, 75334805 bytes; actions: transmit exceeded 0 packets, 0 bytes; actions: drop violated 0 packets, 0 bytes; actions: drop conformed 143000 bps, exceeded 0000 bps, violated 0000 bps Class-map: QOS_Class_Video_DSCP_out (match-any) 0 packets, 0 bytes 30 second offered rate 0000 bps, drop rate 0000 bps Match: access-group name QOS_Video_DSCP_out QoS Set ip precedence 2 Marker statistics: Disabled police: cir 20 %, bc 1000 , be 1000 cir 10240000 bps, bc 1280000 bytes, be 1280000 bytes conformed 0 packets, 0 bytes; actions: transmit exceeded 0 packets, 0 bytes; actions: drop violated 0 packets, 0 bytes; actions: drop conformed 0000 bps, exceeded 0000 bps, violated 0000 bps Class-map: QOS_Class_Callsigna_Business_DSCP_out (match-any) 307355 packets, 41586287 bytes 30 second offered rate 37000 bps, drop rate 0000 bps Match: access-group name QOS_Callsigna_DSCP_out Match: access-group name QOS_Business_ACL_out Match: access-group name port_bgp_qos Queueing queue limit 80 packets (queue depth/total drops/no-buffer drops) 0/0/0 (pkts output/bytes output) 307355/41586287 bandwidth 40% (20480 kbps) Exp-weight-constant: 9 (1/512) Mean queue depth: 0 packets dscp Transmitted Random drop Tail drop Minimum Maximum Mark pkts/bytes pkts/bytes pkts/bytes thresh thresh prob default 0/0 0/0 0/0 220 488 1/10 cs4 163026/13987991 0/0 0/0 30 40 1/10 af41 144329/27598296 0/0 0/0 35 40 1/10 QoS Set ip precedence 4 Marker statistics: Disabled Class-map: QOS_Class_Besteffort_DSCP_out (match-all) 9044048 packets, 2980729029 bytes 30 second offered rate 4366000 bps Match: access-group name QOS_Besteffort_DSCP_out Class-map: class-default (match-any) 6633 packets, 686870 bytes 30 second offered rate 3000 bps, drop rate 1000 bps Match: any Queueing queue limit 64 packets (queue depth/total drops/no-buffer drops) 0/1670/0 (pkts output/bytes output) 9418754/3054796223 bandwidth 20% (10240 kbps) Exp-weight-constant: 9 (1/512) Mean queue depth: 0 packets dscp Transmitted Random drop Tail drop Minimum Maximum Mark pkts/bytes pkts/bytes pkts/bytes thresh thresh prob default 9048853/2979467532 0/0 0/0 30000000 45000000 1/10 ef 369901/75328691 0/0 12/2700 30 32 1/10 QoS Set ip precedence 0 Marker statistics: Disabled
looking at your configuration, your are using a lot of policers in your queuing. What is the total bandwidth available on your link ? Try and you shape average instead...
Hi Pauwen The total bandwidth available is 50M.What is the cause of the loss of packets?
try and change the policers to shapers:
policy-map QOS_VRF_CN1_CN2_out.Child
class QOS_Class_Voice_DSCP_out
set ip precedence 5
shape average 10000000
class QOS_Class_Video_DSCP_out
set ip precedence 2
class QOS_Class_Callsigna_Business_DSCP_out
bandwidth percent 40
random-detect dscp-based
random-detect dscp 0 220 488
set ip precedence 4
class QOS_Class_Besteffort_DSCP_out
class class-default
bandwidth percent 20
random-detect dscp 0 30000000 45000000
set ip precedence 0
policy-map QOS_VRF_CN1_out.Parent
class class-default
shape average 51200000
service-policy QOS_VRF_CN1_CN2_out.Child
policy-map QOS_VRF_CN1_CN2_in
class QOS_Class_Voice_PRE_in
set ip dscp ef
class QOS_Class_Callsigna_Business_PRE_in
set ip dscp af31
class QOS_Class_Besteffort_PRE_in
set ip dscp default
class QOS_Class_Video_PRE_in
set ip dscp cs4
