Packs drop on a non-congest link (for Voice)
whx007007007
Hi Everyone
I have a question regarding QOS packs drop on a non-congest link
My router Gi0/0 connects to ISP and here's the QOS configuration under this port:
QOS:
class-map match-any h_out
match ip precedence 4
class-map match-any l_out
match ip precedence 2
class-map match-any Voice_out
match ip precedence 5
policy-map Traffice-priority
class Voice_out
    priority 320
class h_out
    bandwidth percent 24
class l_out
    bandwidth percent 16
class class-default
    bandwidth percent 38
policy-map SHAPER-WAN
class class-default
    shape average 1500000
  service-policy Traffice-priority
interface GigabitEthernet0/0
description "CE e1"
bandwidth 1544
ip address X.X.X.X Y.Y.Y.Y
load-interval 30
duplex full
speed 10
service-policy output SHAPER-WAN
Show Output:
Router#show policy-map interface gigabitEthernet 0/0
GigabitEthernet0/0
  Service-policy output: SHAPER-WAN
    Class-map: class-default (match-any)
      19559 packets, 7543324 bytes
      30 second offered rate 251000 bps, drop rate 47000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/1110/0
      (pkts output/bytes output) 18468/6056654
      shape (average) cir 1500000, bc 6000, be 6000
      target shape rate 1500000
      Service-policy : Traffice-priority
        queue stats for all priority classes:
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 15623/4935338
        Class-map: Voice_out (match-any)
          16733 packets, 6335376 bytes
          30 second offered rate 207000 bps, drop rate 47000 bps  ------------------------------->you can see that 30 second offered rate is 207000bps which is less than priority 320 kbps, why there are some drop from this class?
          Match: ip precedence 5
            30 second rate 207000 bps
          Match: ip dscp ef (46)
            0 packets, 0 bytes
            30 second rate 0 bps
          Priority: 320 kbps, burst bytes 8000, b/w exceed drops: 1110
        Class-map: h_out (match-any)
          0 packets, 0 bytes
          30 second offered rate 0 bps, drop rate 0 bps
          Match: ip precedence 4
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 0/0
          bandwidth 24% (360 kbps)
        Class-map: l_out (match-any)
          0 packets, 0 bytes
          Match: ip precedence 2
            0 packets, 0 bytes
          Queueing
          bandwidth 16% (240 kbps)
          2826 packets, 1207948 bytes
          30 second offered rate 46000 bps, drop rate 0 bps
          Match: any
          Queueing
          (pkts output/bytes output) 2845/1121316
          bandwidth 38% (570 kbps)
My question is marked as Red, could anyone share some thought about that ?
Thanks a lot
jamie.grive
Hmm - the configuration is good, the only thing I can think of is you are exhausting the shaper token buckets because of bursty traffic.
Is there any TCP traffic getting marked as Prec 5 that could be entering this queue?
Please try doubling the bucket sizes and seeing if that resolves - and then investigate what traffic might be causing this if that works.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
You're looking at a 30 average rate, but policing happens in milliseconds.  I.e. your traffic goes overrate within a millisecond time window (looks like 200ms) it will be dropped.
May I know where you find my  traffic goes overrate within a millisecond time window? Thanks
Disclaimer
Posting
You infer that from knowing how it works and the fact it's recording drops, but also:
            0 packets, 0 bytes
