Packt Drop in Physical Interface
biplobkhan
A number of my branch router is connect to Head office.
one branch is connect through Layer 2.
I show physical  interface  then found Packet drop .
But when ping HO- LAN to Branch- LAN through Computer then no ping lose.
Can you tell what is the probability problem in packet drop , what I take the step for resulation.
Configuration in Branch Router:
interface FastEthernet0/0
ip address 192.168.X.X 255.255.255.0
ip tcp adjust-mss 1460
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.X.X 255.255.255.248
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.X.1
no ip http server
no ip http secure-server
regards
Biplob
biplobkhan
Data-Center#ping 192.168.X.X repeat 100
Sending 100, 100-byte ICMP Echos to 192.168.63.209, timeout is 2 seconds:
Success rate is 92 percent (92/100), round-trip min/avg/max = 16/30/108 ms
Data-Center#
