padi timer expired on my UC560
Makrem YAHYAOUI
hello,
I am trying to configure PPPoE over modem ADSL "brdige mode" on UC560 and  the PPPoE session is coming up and all thing are fine and the client have no trouble, after two month i do a shut and no shut on the dialer , and i lost the pppoe session and I am receiving the following from PPPoE debug:
i don't know what i  have to do, i have contacted the ISP and no answer  PLease Help, i have more than 2 week steel looking for a solution
142103:  padi timer expired
142104:  Sending PADI: Interface = GigabitEthernet0/0
142105: pppoe_send_padi:
contiguous pak, size 60
         FF FF FF FF FF FF D8 67 D9 99 C2 D1 88 63 11 09
         00 00 00 10 01 01 00 00 01 03 00 08 AD 00 00 09
         00 00 1F B0 00 00 00 00 00 00 00 00 00 00 00 00
142106:  padi timer expired
142107:  Sending PADI: Interface = GigabitEthernet0/0
142108: pppoe_send_padi:
142109:  padi timer expired
142110:  Sending PADI: Interface = GigabitEthernet0/0
142111: pppoe_send_padi:
And this is the config of the outside interface and the dialer
interface GigabitEthernet0/0
description $FW_OUTSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip access-group 109 in
no ip redirects
no ip unreachables
no ip proxy-arp
  ip mtu 1492
ip nat outside
ip inspect SDM_MEDIUM out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname aaaaa
ppp chap password bbbbb
ppp pap sent-username aaaaa password bbbbb
down-when-looped
no cdp enable
crypto map VPN_STS
service-policy input sdmappfwp2p_SDM_MEDIUM
service-policy output sdmappfwp2p_SDM_MEDIUM
ip nat inside source list 199 interface Dialer1 overload
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 192.168.1.6 5
access-list 10 permit any
Get an analog handset, unplug the POTS (ADSL) service from your ADSL modem and plug it to analog handset. You should be getting a dial tone and able to dial out.
Let me know ehat is the outcome.
the POTS service. Have you contacted your ISP?
Please rate replies and mark question as "answered" if applicable.
9 Replies 9
Rejohn Cuares
Level 4
Level 4
Enable debug ppp authentication and post the output here
Hi rr_cuares,
here is the only output of the debug ppp authentication
UC560#sh debugging
PPP:
  PPP authentication debugging is on
  PPP protocol negotiation debugging is on
PPPoE:
  PPPoE protocol events debugging is on
  PPPoE control packets debugging is on
  PPPoE protocol errors debugging is on
148568:  padi timer expired
148569:  Sending PADI: Interface = GigabitEthernet0/0
148570: pppoe_send_padi:
148571:  padi timer expired
148572:  Sending PADI: Interface = GigabitEthernet0/0
148573: pppoe_send_padi:
148574:  padi timer expired
148575:  Sending PADI: Interface = GigabitEthernet0/0
148576: pppoe_send_padi:
148577:  padi timer expired
148578:  Sending PADI: Interface = GigabitEthernet0/0
148579: pppoe_send_padi:
148580:  padi timer expired
148581:  Sending PADI: Interface = GigabitEthernet0/0
148582: pppoe_send_padi:
148583:  padi timer expired
148584:  Sending PADI: Interface = GigabitEthernet0/0
148585: pppoe_send_padi:
UC560#sh de
148586:  padi timer expired
148587:  Sending PADI: Interface = GigabitEthernet0/0
148588: pppoe_send_padi:
Rejohn Cuares
Level 4
Level 4
You are not getting any PPPoE offer (PADO) from ISP.
Have you tried reloading the ADSL modem?
Yes i'm not getting any PADI from ISP,
I reload the ADSL modem more than one time, and the situation steel the same
Hello rr_cuares
Sorry it's not the good answer,
I do it and everything is fine, i can connect to internet when i put the modem on PPPOE mode.
but not the same with bridge mode.
I ask my ISP and they said from their side they don't have any problem, i change the modem twice. and no solution.
i don't know; i dont have any idea how to resolve it.
Okay this rule out the issue on the line, as you said it works fine when you set the ADSL modem as PPPoEclient.
This could be a config issue on the ADSL modem. What type of modem you have?
i'm working with sagem F@st 1704, and the config is the same on other modem with another topology.
I found this link over the internet on how to setup Sagem in bridge mode.
tinyurl.com/bridging-mode
