Part No. ISR 4221 Router
Nishant Patil
Please recommend part no. for Mounting Bracket for Cisco ISR4221/K9.
M02@rt37
Hello @Nishant Patil,
For the 4221, check the 23 inch bracket.
ACS-4220-RM-23
--Figure 3-9 Bracket Installation for Front Mounting (Cisco 4221 ISR shown) here:
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Install_Connect.html
Best regards
M02@rt37
ACS-4220-RM-23
Best regards
balaji.bandi
it generally come with the kit (if that is misplaced then look equivalent in the local market)
check installation guide for the spec
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Install_Connect.html?bookSearch=true
BB
