partition flash 2 10 2 % Invalid input detected at '^' marker.
vannacisco
Got the follwing error after upgrading router 837.Follwing is the complete error.
% Crashinfo may not be recovered at flash:crashinfo
% This file system device reports an error.
Follwing is my Flash Info:
System flash directory, partition 1:
File Length Name/status
1 10043888 flash
[10043952 bytes used, 441804 available, 10485756 total]
10240K bytes of processor board System flash (Read/Write)
System flash directory, partition 2:
No files in System flash
[0 bytes used, 1835004 available, 1835004 total]
2048K bytes of processor board System flash (Read/Write)
Do i need torevert back to old ios.
I had ios 12.4-5b upgraded to 12.4-23.
thnx!
htarra
Level 4
Level 4
Use the max max-wattage option to disallow higher-power powered devices. With this configuration, when the powered device sends Cisco Discovery Protocol (CDP) messages requesting more power than the maximum wattage, the switch removes power from the port. If the powered-device IEEE class maximum is greater than the maximum wattage, the switch does not power the device. The power is reclaimed into the global power budget.
For further information please follow up with the link below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/command/reference/cli1.html#wp10762288
