Passing internet Traffic over GRE Tunnel
mudvayne15
Hi Everyone,
Need help on how to force the traffic from 10.10.10.1 AWS Server to the Internet over GRE tunnel
I have a tunnel established between AWS and Cisco and we have tested to route internet traffic over GRE but it did not go through.
I have a default route to the internet and the other option that I have not tried is to create a route map.
The configuration of the tunnel on cisco
interface Tunnel1
ip address 192.168.1.2 255.255.255.252
ip virtual-reassembly
ip tcp adjust-mss 1387
shutdown
tunnel source 2.2.2.2
tunnel destination 3.3.3.3
tunnel mode ipsec ipv4
tunnel protection ipsec profile ipsec-vpn-243c4476-1
ip route 0.0.0.0 0.0.0.0 172.31.1.2
The route map below is I haven't tried yet, do you have other suggestions to do this?
access-list 110 permit ip 10.10.10.1 255.255.255.255
route-map AWS_To_Internet permit 50
match ip address 110
set ip next-hop 172.31.1.1
2 Accepted Solutions
the route map you initially had in mind could be an option. Use that in combination with policy routing (applied to the physical interface connecting the 4431 to AWS. This should look something like below:
access-list 110 permit ip host 10.10.10.1 any
set ip next-hop 172.31.1.2
interface GigabitEthernet0/0
description Link to AWS
ip policy route-map AWS_To_Internet
Hello
Your config looks fine, just append the policy based route-map to the lan interface that you acl host reside in
int x/x
Description lan host subnet
ip policy route-map xxx
Kind Regards
Paul
5 Replies 5
is the traffic from AWS actually arriving at your 4431 router ? The default route should be sufficient, provided you have all the NAT configuration in place.
Post the full running configuration (sh run) of the 4431.
Hi Georg,
Thanks for getting back to me, the traffic between the tunnel is good. The only thing we want is that 1 server to only access the Internet, since there are a bunch of servers on the AWS side. I might have not showed the completed diagram but on the Cisco side, there is another router as well.
Aside from adding NAT, is there anything else that we can do on this?
Hello
int x/x
Kind Regards
Paul
mudvayne15
Thank you everyone, I will try it and let you know the results.
