password not set wasiting fo
davidexyte
i signed in to a new ISR 1100 series router and get this message after the configuration finished installing and prompted to there a new password  %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config
henrique3
Does anybody know how to solve this? You wouldn't assume setting up a Cisco router to be so tricky since the manual indicates the initial configuration would do the job, but it doesn't. Can anyone provide a beam of light here?
GajendraKD
I had the same issue here is what I tried that help me to save my new Admin password along with stopping popping those massages.
Router#pnpa service discovery stop
Waiting for PnP discovery cleanup ..
*Feb 14 00:32:52.112: %PNP-6-PNP_DISCOVERY_STOPPING: Stopping PnP Discovery. Please do not interrupt
*Feb 14 00:33:01.772: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
Router#
Router#
GajendraKD
Here are the output from my router.
Router#
*Feb 14 00:27:46.739: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:28:01.737: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:28:16.743: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:28:31.749: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:28:46.751: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:29:01.753: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:29:16.753: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:29:31.753: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:29:46.756: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
Router#
Router#
*Feb 14 00:30:01.763: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
*Feb 14 00:32:01.769: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:32:16.772: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
Router#
Router#
Router#config-transaction
System is still initializing. Wait for PnP to be completed or terminate PnP with the following command:
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
*Feb 14 00:33:07.114: %PNP-6-PNP_DISCOVERY_ABORT_ON_CLI: PnP Discovery abort on CLI input
*Feb 14 00:33:07.210: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Feb 14 00:33:07.211: %PNP-6-PNP_SAVING_TECH_SUMMARY: Saving PnP tech summary (/pnp-tech/pnp-tech-discovery-summary)... Please wait. Do not interrupt.
*Feb 14 00:33:07.116: %DMI-5-SYNC_NEEDED: R0/0: dmiauthd: Configuration change requiring running configuration sync detected - 'Sync and activate IPC'. The running configuration will be synchronized to the NETCONF running data store.
*Feb 14 00:33:07.356: %DMI-5-SYNC_START: R0/0: dmiauthd: Synchronization of the running configuration to the NETCONF running data store has started.
*Feb 14 00:33:07.459: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Feb 14 00:33:07.675: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Feb 14 00:33:07.776: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
*Feb 14 00:33:07.905: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
Router#
Router#
Router#
Router#
Router#
*Feb 14 00:33:08.028: %PNP-6-PNP_SUDI_UPDATE: Device SUDI [PID:IR1101-K9,SN:FCW2650YNUB] identified
*Feb 14 00:33:08.456: %SYS-5-CONFIG_P: Configured programmatically by process PnP Agent Discovery from console as vty0
Router#
Router#
Router#
Router#
Router#
*Feb 14 00:33:08.555: %PNP-6-PNP_TECH_SUMMARY_SAVED_OK: PnP tech summary (/pnp-tech/pnp-tech-discovery-summary) saved successfully (elapsed time: 1 seconds).
*Feb 14 00:33:09.729: %PNP-6-PNP_DISCOVERY_ABORT_ON_CLI: PnP Discovery abort on CLI input
*Feb 14 00:33:09.729: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Discovery Aborted)
*Feb 14 00:33:13.490: %DMI-5-SYNC_COMPLETE: R0/0: dmiauthd: The running configuration has been synchronized to the NETCONF running data store.
*Feb 14 00:33:14.025: %SYS-5-CONFIG_P: Configured programmatically by process iosp_conn_100001_vty_100001 from console as NETCONF on vty4294967286
*Feb 14 00:33:14.009: %DMI-5-CONFIG_I: R0/0: dmiauthd: Configured from NETCONF/RESTCONF by system, transaction-id 463
*Feb 14 00:33:14.489: %SYS-5-CONFIG_P: Configured programmatically by process iosp_conn_100001_vty_100001 from console as NETCONF on vty4294967286
*Feb 14 00:33:14.924: %SYS-5-CONFIG_P: Configured programmatically by process iosp_conn_100001_vty_100001 from console as NETCONF on vty4294967286
*Feb 14 00:33:15.377: %SYS-5-CONFIG_P: Configured programmatically by process iosp_conn_100001_vty_100001 from console as NETCONF on vty4294967286
*Feb 14 00:33:15.553: %IOSXE-5-PLATFORM: R0/0: vip-bootstrap: Password recovery not set
*Feb 14 00:33:16.886: %SYS-5-CONFIG_P: Configured programmatically by process iosp_conn_100001_vty_100001 from console as NETCONF on vty4294967286
*Feb 14 00:33:16.852: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:33:17.948: %IOSXE-5-PLATFORM: R0/0: vip-bootstrap: ConfD started in phase2
*Feb 14 00:33:27.020: %INSTALL-5-INSTALL_START_INFO: R0/0: install_engine: Started install commit PACKAGE
*Feb 14 00:33:28.007: %INSTALL-5-INSTALL_COMPLETED_INFO: R0/0: install_engine: Completed install commit PACKAGE
*Feb 14 00:33:31.794: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:33:33.796: %Cisco-SDWAN-Router-CXPD-6-INFO-2700001: R0/0: CXPD: Starting
*Feb 14 00:33:34.540: %Cisco-SDWAN-Router-DBGD-6-INFO-2900001: R0/0: DBGD: Starting
*Feb 14 00:33:37.122: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class added : class '__all_tunnels__' at index '0' loss = N/A, latency = N/A, jitter = N/A, app-probe-class = None
*Feb 14 00:33:37.260: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: FTM-TCPD: init ftm_tcpd!
*Feb 14 00:33:37.260: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: FTM-TCPD: Initialized message queue to with TCPD!
*Feb 14 00:33:37.260: %Cisco-SDWAN-Router-FTMD-6-INFO-1000036: R0/0: FTMD: FTM DBGD : Initialized message queue
*Feb 14 00:33:37.536: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300001: R0/0: CFGMGR: Connection to ftm is up
*Feb 14 00:33:37.538: %Cisco-SDWAN-Router-FTMD-4-WARN-1000001: R0/0: FTMD: Connection to CFGMGR is up
*Feb 14 00:33:37.770: %Cisco-SDWAN-Router-FTMD-6-INFO-1000036: R0/0: FTMD: Connection to DBGD came up
*Feb 14 00:33:38.036: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Feb 14 00:33:38.473: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Feb 14 00:33:38.555: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x55abe8baf0 p_ftm 0x5575db5640
*Feb 14 00:33:47.101: %Cisco-SDWAN-RP_0-CFGMGR-4-WARN-300005: R0/0: CFGMGR: New admin password not set yet, waiting for daemons to read initial config.
*Feb 14 00:34:09.521: %AAAA-4-CLI_DEPRECATED: WARNING: Command has been added to the configuration using a type 5 password. However, type 5 passwords which are considered weak are now deprecated.
*Feb 14 00:34:09.873: %SYS-5-CONFIG_P: Configured programmatically by process iosp_conn_100001_vty_100001 from console as NETCONF on vty4294967286
*Feb 14 00:34:09.589: %DMI-5-CONFIG_I: R0/0: dmiauthd: Configured from NETCONF/RESTCONF by cfgmgr, transaction-id 607
*Feb 14 00:34:09.957: %Cisco-SDWAN-RP_0-CFGMGR-6-INFO-300005: R0/0: CFGMGR: Successfully set new admin password
Router#
Router#
Router#
Router#
Router#
Router#
Router#
*Feb 14 00:37:54.990: %LINK-3-UPDOWN: Interface FastEthernet0/0/1, changed state to down
*Feb 14 00:37:54.996: %LINK-3-UPDOWN: Interface Vlan1, changed state to down
*Feb 14 00:37:55.990: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/1, changed state to down
*Feb 14 00:37:55.994: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Router#
Router#
Router#
Router#
GajendraKD
It will save your new password as well./
