password recovery for cisco 3548 xl
trikjester
Greetings all,  I am a student pursuing a CCNA certification currently.  I recently came across a lot of 3548 xl switches.  They power up fine, post with out problem and load flash.  The problem I am running into is that the console is password protected.  I have found the password recovery procedure for this switch, but it requires the use of the mode button.  I have tried this process several times and the flash file is loaded with the startup config file.  How do I perform a password recovery on a switch with a broken mode button?  Thank you in advance
Leo Laohoo
Try letting the switch stand on the front panel so that the entire weight of the switch is resting on the front panel.
