password recovery on 2600 doesn't work
barry-goldberg
I'm trying to recover forgotten password on the 2600 router. I have been doing exactly as it written in the document however no luck.
this what i do
reboot into rommon > confreg 0X2142
reset
no on the promt
enable
copy startup-config running config
show running config
i have the folowwing at the end of the file
line con 0
exec-timeout 0 0
password xxx
login
transport input none
line aux 0
line vty 0 4
password xxx
login
conf t
enable secret test
no shutdown on each interface
config-register 0x2102
after restart i can't get into router
Please let me know what I'm doing wrong
thank you for your help
You changed the enable password but did not change the console password.
Perform password recovery again and set the line console password as follows.
line con 0
pass
Sundar
line con 0
pass
Sundar
