Password recovery
Luisinus
I bought a 1841 Router on e-bay.
Apparently, it has been configured with "no service password-recovery". The console shows: PASSWORD RECOVERY FUNCTIONALITY IS DISABLED, and it does not respond to Ctrl-Break during boot. AFAIK, this router does not have a removable NVRAM chip - so this method of reset is excluded. Is my only option to RMA it?
TIA, /Luis
15 Replies 15
Yahooo!!!
I put the following image on the compact flash
c1841-advipservicesk9-mz.124-20.T.bin
I then power cycled the router and entered the break sequence after the image had decompressed #####[ok]  ( I also pressed it a couple of times a few seconds after.
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x235aa60
Self decompressing the image : #################################################
####################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
                0X003AA110 public buffer pools
                0X00211000 public particle pools
                0X00020000 Crypto module pools
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 2785644 bytes to IO Memory.
PMem allocated: 122683392 bytes; IOMem allocated: 11534336 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(20)T,
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jul-08 20:28 by prod_rel_team
PASSWORD RECOVERY IS DISABLED.
Do you want to reset the router to factory default
configuration and proceed [y/n] ?
Reset router configuration to factory default.
