PAT interfers with Web Server Access over L2 tunnel (thought that is was solved)
I posted this already but my mistake, it is not solved.
I'm working on a network to accomplish 3 things:
1) NAT overload to the internet
2) L2 tunnels to remote users
3) PAT subcontractors to the Web server on the outside interface with port mapping
PROBLEM STATEMENT
Everything is working except the PAT (ip nat inside source static tcp 192.168.175.66 80 interface GigabitEthernet0/0 8080) stops the remote user (over the L2 tunnel) from accessing the web server.  If I remove t he PAT,  Web access for the remote user is good.  See the tcpdump on the Web Server showing http coming in but not getting out (note length 0 shows that the hand-shake fails).
QUESTION
How can I change to PAT to allow normal access to the Web Server over L2.
This is the test configuration I'm using to simulate the WAN.  Attached are the two configurations and the tcpdump.
17 Replies 17
I'll work on it a little more and then send all the configs.
At least I can ping the RTR gi0/0.175 now from the switch and a PC on vlan 175.  whew!!!!!
I really appreciate you help.  Thank you.
Hi Paul, I implemented you changes that you suggested and I'm happy with the results. Thank you :-)
Got the (((Not Domain_based))) nat working using sub-interfaces.  But I have the same PAT issue.  I can't browse to the Apache server from the distant end of the L2 tunnel - the PAT (8080 to 80) to Apache interferes with browsing to Apache (regular port 80).  See the tcpdump at the end - note that the Apache netstat shows no ESTABLISHED connection to the remote browser.  But the remote PC can reach http://192.168.168.235:8080 now because of the change to sub-interfaces
Here are the configurations and a template for adding another remote L2 client.
CONFIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!LOCALSW!!!!!!!!!!!!!!!!!!!!!!!!!!!!
 interface FastEthernet0/13
  description trunk_to_localrtr
  switchport encapsulatoin dot1q
  switchport trunk allowed vlan 1,175
  switchport mode trunk
 interface FastEthernet0/14
  description local_VM_server
  switchport access vlan 175
  switchport mode access
CONFIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!LOCALRTR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key firewallcx address 192.168.168.236
crypto isakmp key firewallcx address 192.168.168.237
crypto ipsec transform-set TS esp-3des esp-md5-hmac
 mode tunnel
crypto map CMAP 76 ipsec-isakmp
 set peer 192.168.168.236
 set transform-set TS
 match address VPN_TRAFFIC_176
crypto map CMAP 77 ipsec-isakmp
 set peer 192.168.168.237
 match address VPN_TRAFFIC_177
 description OUTSIDE
 ip address 192.168.168.235 255.255.255.0
 ip nat enable
 ip virtual-reassembly in
 crypto map CMAP
interface GigabitEthernet0/1
 description INSIDE
 no ip address
 ip nat enable
interface GigabitEthernet0/1.175
 description INSIDE_175
 encapsulation dot1Q 175
 ip address 192.168.175.1 255.255.255.0
 ip nat enable
ip nat source list 175 interface GigabitEthernet0/0 overload
! Note this prevents L2 tunnels from browsing to http://192.168.175.66:80
! remote sites have to use http://192.168.168.235:8080
ip nat source static tcp 192.168.175.66 80 interface GigabitEthernet0/0 8080
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.168.1
ip route 192.168.176.0 255.255.255.0 192.168.168.236
ip route 192.168.177.0 255.255.255.0 192.168.168.237
ip access-list extended VPN_TRAFFIC_176
 permit tcp 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
ip access-list extended VPN_TRAFFIC_177
 permit tcp 192.168.175.0 0.0.0.255 192.168.177.0 0.0.0.255
 permit ip 192.168.175.0 0.0.0.255 192.168.177.0 0.0.0.255
access-list 175 remark -=[Define NAT Service]=-
access-list 175 deny   ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
access-list 175 deny   ip 192.168.175.0 0.0.0.255 192.168.177.0 0.0.0.255
access-list 175 permit ip 192.168.175.0 0.0.0.255 any
CONFIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!REMOTESW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  description trunk_to_remotertr
  switchport trunk allowed vlan 1,176
 interface FastEthernet0/2
  description remote_PC_192_168_176_3
  switchport access vlan 176
CONFIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!REMOTERTR1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ip dhcp excluded-address 192.168.176.1 192.168.176.2
ip dhcp excluded-address 192.168.176.64 192.168.176.255
ip dhcp pool DHCPPOOL
 network 192.168.176.0 255.255.255.0
 dns-server 192.168.168.200 192.168.168.1
 default-router 192.168.176.1
 lease 0 2
 encr 3des
 hash md5
 group 2
crypto isakmp key firewallcx address 192.168.168.235
 mode tunnel
crypto map CMAP 10 ipsec-isakmp
 set peer 192.168.168.235
 description OUTSIDE
 ip address 192.168.168.236 255.255.255.0
 crypto map CMAP
 description INSIDE
 no ip address
interface GigabitEthernet0/1.176
 description INSIDE_176
 encapsulation dot1Q 176
 ip address 192.168.176.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.168.1
ip route 192.168.175.0 255.255.255.0 192.168.168.235
 permit tcp 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
CONFIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!REMOTESW2!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  switchport trunk allowed vlan 1,177
  description remote_PC_192_168_177
  switchport access vlan 177
CONFIG!!!!!!!!!!!!!!!!!!!!!!!!!REMOTERTR2!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ip dhcp excluded-address 192.168.177.1 192.168.177.2
ip dhcp excluded-address 192.168.177.64 192.168.177.255
 network 192.168.177.0 255.255.255.0
 default-router 192.168.177.1
 lease 0 2
 encr 3des
 hash md5
 group 2
 mode tunnel
 description OUTSIDE
 ip address 192.168.168.237 255.255.255.0
 crypto map CMAP
 description INSIDE
 no ip address
interface GigabitEthernet0/1.177
 description INSIDE_177
 encapsulation dot1Q 177
 ip address 192.168.177.1 255.255.255.0
 permit tcp 192.168.177.0 0.0.0.255 192.168.175.0 0.0.0.255
 permit ip 192.168.177.0 0.0.0.255 192.168.175.0 0.0.0.255
TEMPLATE--------------================REMOTERTR=================--------------------------------
no ip dhcp conflict logging
 lease 0 2
 encr 3des
 hash md5
 group 2
 mode tunnel
 description OUTSIDE
 duplex auto
 speed auto
 crypto map CMAP
 description INSIDE
 no ip address
 duplex auto
 speed auto
TEMPLATE--------------==============LOCALRTR===================--------------------------------
TEMPLATE--------------=================================--------------------------------
===TCPDUMP on Apache Server 192.168.175.66 - client PC_Browser on 192.168.176.3===
[root@apache myuser]# tcpdump -i -vv enp0s3 | grep 192.168.176.3
tcpdump: -vv: No such device exists
(SIOCGIFHWADDR: No such device)
[root@apache myuser]# tcpdump -vv -i enp0s3 | grep 192.168.176.3
tcpdump: listening on enp0s3, link-type EN10MB (Ethernet), capture size 262144 bytes
    192.168.176.3.49345 > apache.myco.com.http: Flags [S], cksum 0x3052 (correct), seq 1850609357, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
    apache.myco.com.http > 192.168.176.3.49345: Flags [S.], cksum 0xe0bd (incorrect -> 0x9d84), seq 1779422871, ack 1850609358, win 29200, options [mss 1460,nop,nop,sackOK,nop,wscale 7], length 0
    192.168.176.3.49345 > apache.myco.com.http: Flags [R], cksum 0x13ff (correct), seq 1850609358, win 0, length 0
    192.168.176.3.49346 > apache.myco.com.http: Flags [S], cksum 0x7ae5 (correct), seq 391912235, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
    apache.myco.com.http > 192.168.176.3.49346: Flags [S.], cksum 0xe0bd (incorrect -> 0xab44), seq 1029849112, ack 391912236, win 29200, options [mss 1460,nop,nop,sackOK,nop,wscale 7], length 0
    192.168.176.3.49346 > apache.myco.com.http: Flags [R], cksum 0xa926 (correct), seq 391912236, win 0, length 0
    apache.myco.com.http > 192.168.176.3.49345: Flags [S.], cksum 0xe0bd (incorrect -> 0xf28d), seq 1826455232, ack 1850609358, win 29200, options [mss 1460,nop,nop,sackOK,nop,wscale 7], length 0
    apache.myco.com.http > 192.168.176.3.49346: Flags [S.], cksum 0xe0bd (incorrect -> 0xf902), seq 1076883340, ack 391912236, win 29200, options [mss 1460,nop,nop,sackOK,nop,wscale 7], length 0
    192.168.176.3.49345 > apache.myco.com.http: Flags [S], cksum 0x445b (correct), seq 1850609357, win 8192, options [mss 1460,nop,nop,sackOK], length 0
    apache.myco.com.http > 192.168.176.3.49345: Flags [S.], cksum 0xe0b9 (incorrect -> 0x03fb), seq 1920302025, ack 1850609358, win 29200, options [mss 1460,nop,nop,sackOK], length 0
    192.168.176.3.49346 > apache.myco.com.http: Flags [S], cksum 0x8eee (correct), seq 391912235, win 8192, options [mss 1460,nop,nop,sackOK], length 0
    apache.myco.com.http > 192.168.176.3.49346: Flags [S.], cksum 0xe0b9 (incorrect -> 0x1dae), seq 1170725207, ack 391912236, win 29200, options [mss 1460,nop,nop,sackOK], length 0
Paul I tried to give you well deserved credit but I can't find the place to put 5 STARS.... I really appreciate your help. You're the best ***** 5 STARS
