BGP,VTI with ipsec got recursive route lookup error
MrBeginner
Dear all,
When I create VTI with ipsec in my network,I got recursive route lookup error and tunnel is up and down again  again.I am using DGP to peer with ISP and default route also.when I set static to my tunnel ,i got rrecursiv route lookup error message and tunnel is down.
Nov 23 03:44:31.327: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
*Nov 23 03:45:31.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
*Nov 23 03:45:31.331: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1 - looped chain attempting to stack
*Nov 23 03:45:41.331: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
*Nov 23 03:45:41.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
*Nov 23 03:46:41.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
*Nov 23 03:46:41.335: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1 - looped chain attempting to stack
*Nov 23 03:46:51.335: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
*Nov 23 03:46:51.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
Thanks for the update telling us that you have solved the issue with the static route. Perhaps there is something in your follow up question that I am not understanding correctly. But I do not see any issue in what you have posted about sharing proposal, transform set, and policy.
Rick
Rick
12 Replies 12
recursive routing usually means the best path to the tunnel destination is through the tunnel itself. Make sure that is not the case. Best to post the full config of your router...
Before i put static route to tunnel interface network is ok Tunnel is UP. and i can ping my loopback interface to remote interface.
After i static route to tunnel interface tunnel got that problem.It is routing protocol issue ?
Which route is pointing towards the tunnel ?
Post the config of your router, without seeing that, it is just guesswork...
Please see the configuration. before static route (not default route) tunnel is up and i can ping loopback interface to interface.my network is work properly under BGP transport.
When my route apply to tunnel ,tunnel is down.
my-r1#sh run
Building configuration...
Current configuration : 9290 bytes
! Last configuration change at 21:36:59 SGD Wed Nov 21 2018
version 15.5
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname my-r1
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
clock timezone SGD 8 0
crypto pki trustpoint my-ca
enrollment terminal
serial-number none
ip-address none
subject-name cn=r1.my.local
revocation-check none
fqdn none
rsakeypair my-ca 2048
ip cef
crypto ikev2 proposal aes-cbc-256-proposal
encryption aes-cbc-256
integrity sha256
group 14
crypto ikev2 policy policy1
match address local 10.10.10.1
crypto ikev2 profile profile1
description IKEv2 profile
match identity remote any
identity local dn
authentication local rsa-sig
authentication remote rsa-sig
crypto ipsec transform-set ESP-AES-SHA esp-aes 256 esp-sha256-hmac
mode tunnel
crypto ipsec profile VTI-IPSecProfile
set transform-set ESP-AES-SHA
set ikev2-profile profile1
crypto map SDM_CMAP_1 1 ipsec-isakmp
! Incomplete
set peer 13.13.13.13
! access-list has not been configured yet
set pfs group14
match address 103
interface Tunnel1
ip address 1.1.1.1 255.255.255.0
tunnel source GigabitEthernet9
tunnel mode ipsec ipv4
tunnel destination 13.13.13.13
tunnel protection ipsec profile VTI-IPSecProfile
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
duplex auto
speed auto
interface GigabitEthernet9
ip address 10.10.10.1 255.255.255.240
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip route 20.20.20.0 255.255.255.0 Tunnel1
router bgp 65300
no synchronization
bgp log-neighbor-changes
network 10.1.2.0 mask 255.255.255.0
neighbor 10.10.10.2 remote-as 25
neighbor 10.10.10.2 description ISP Peer
no auto-summary
ip access-list 103 10.1.2.0 0.0.0.255 20.20.20.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
my-r1#
post the config of the other side as well...
You need to make sure that the route to the other end of the tunnel is not through the tunnel itself, that is when recursive routing occurs...
Other side it PA firewall. Router is also run BGP peer with ISP also.After that PA firewall .PA firewall to router is using Static route.
ip route 13.13.13.13 255.255.255.255 10.10.10.2
Hi ,
May i know this error is because of AD value ?
because i use bgp for isp peering and static route for IPSec ? May i know ,please
In the config that you posted there are two static routes. One is the static default route and the other appears to be a route for the remote network reached through the tunnel. I do not see issues with these routes. Can you give us the specifics of the static route that you are attempting to configure that causes this problem?
I do see a couple of things in the config that I would ask about:
- your outside interface Gig9 is shutdown. Is that on purpose?
- your configuration of BGP has a network statement for 10.1.2.0 255.255.255.0 but I do not see anything in the configuration about that network. What is it and where is it?
- it looks like you originally intended to do ipsec with a crypto map and then changed to use vti. You might want to remove the crypto map and acl 103 from the config.
Rick
Rick
MrBeginner
Dear All,
PLease help me to solve.
Hi All,
I can solved now. I removed romte interface subnet in my static route.Last time i point the whole route include remote interface.So my tunnel leaned itself. Thanks for your help. and I would like to know
can i use share proposal ,transformset and policy. Please see below config sample and advice me.
crypto ikev2 proposal aes-cbc-256-proposal1
integrity sha256
group 14
match address local 2.1.1.1
crypto ipsec transform-set TS-ESP-AES-SHA esp-aes 256 esp-sha256-hmac
mode tunnel
match identity remote address 123.1.1.1
identity local address 2.1.1.1
crypto ipsec profile IPSecProfile
set transform-set TS-ESP-AES-SHA
set ikev2-profile profile2
interface Tunnel2
description For branch to AWS
ip address 1.1.1.5 255.255.255.252
tunnel source g9
tunnel destination 123.1.1.1
tunnel protection ipsec profile IPSecProfile
crypto ikev2 profile profile2
match identity remote address 12.2.2.2
interface Tunnel2
ip address 172.16.100.1 255.255.255.252
tunnel source 2.1.1.1
tunnel destination 12.2.2.2
ip route 10.10.10.0 255.255.255.0 Tunnel1
ip route 20.20.20.0 255.255.255.0 Tunnel2
Rick
Rick
