PAT issues on a Cisco 2901
JesseSinclair
Hello community, I've been having some difficulties setting up PAT on my 2901 with an otherwise basic configuration.
I've implemented all the required steps for PAT as far as I can tell, there has to be some detail that I'm missing. I configured my inside and outside interfaces, set up the access list for my only subnet as of current and I've linked my ACL to the my outside interface but nothing is being translated, nothing at all is being generated in the nat translation table. Router can ping hosts on the internet and the PC, PC can ping the router but not a host on the internet.
As far as I can tell, the only things that would cause this would be if I've incorrectly configured NAT or if my router isn't set up to facilitate traffic to the internet. Ive got a permit ip any any at the end of my WAN acl and I dont have an ACL on my inside port so I don't think its that. Am I maybe missing a routing table entry?
Any insight would be appreciated. I'll paste my running config below. I'll be able to provide any other relevant information.
2901#show run
Building configuration...
Current configuration : 1862 bytes
! Last configuration change at 21:09:42 UTC Sun Feb 21 2021 by jesse
version 15.4
service password-encryption
hostname 2901
boot-start-marker
boot-end-marker
enable secret 5 [redacted]
no aaa new-model
ip dhcp excluded-address 10.0.0.1 10.0.0.64
ip dhcp pool DHCP
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.1
ip domain name home.lab
ip cef
login block-for 10 attempts 5 within 20
login delay 10
login on-failure log
login on-success log
no ipv6 cef
cts logging verbose
license udi pid CISCO2901/K9 sn FTX143801Q8
username jesse privilege 15 secret 5 [redacted]
redundancy
lldp run
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip access-group WAN in
 ip access-group WAN out
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no lldp transmit
 no cdp enable
interface GigabitEthernet0/1
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list NAT interface GigabitEthernet0/0 overload
ip ssh version 2
ip access-list standard NAT
 permit 10.0.0.0 0.0.0.255
ip access-list extended WAN
 deny   tcp any any eq 22
 permit ip any any
control-plane
line con 0
 logging synchronous
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 login local
 transport input ssh
scheduler allocate 20000 1000
end
Hello
Change to the following and test again...
Ip nat inside source list NAT  .........
Kind Regards
Paul
Hello
Kind Regards
Paul
Ha, amateur move. Won't make that mistake again, thanks Paul. Marked as solution.
in addition to Paul's post, make the changes marked in bold:
2901#show run
version 15.4
hostname 2901
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool DHCP
--> dns server 8.8.8.8 8.8.4.4
ip cef
login delay 10
no ipv6 cef
cts logging verbose
redundancy
lldp run
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
no lldp transmit
no cdp enable
ip nat inside
duplex auto
speed auto
no ip http server
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
--> ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip ssh version 2
permit ip any any
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 15 0
logging synchronous
login local
transport input ssh
end
Hey Georg, I really appreciate that, adding a DNS was the thing I did right after I resolved this issue. I appreciate the tip for the default route, wasnt sure how to do it with DHCP. ill be sure to use that as well.
