PAT/NAT translation not working
SCPMAN
I have been working on a network for one of my classes with the goal being PC10,20,30 to ping Loopback0 interface on the ISP router. The PC's are all DHCP and have been configured correctly and as far as I know the PAT has been as well.
When I try to ping it reply's as host unreachable.
PT file linked.
-ACL is configured on R2 to prevent PC30 ICMP traffic to PC10
-PAT is configured on R1
-OSPF has been configured on the network with full connectivity except for the ISP router which has not been linked
-Default route has been configured on R1 to ISP router
-R3 has is the DHCP router
-Current NAT configuration
int gig0/0/1
ip nat inside
int gig0/0/2
ip nat outside
access-list 1 permit 10.10.0.0. 0.0.255.255
ip nat inside source list interface gig0/0/2 overload
-R1 and R3 are able to ping the ISP interface but not the loopback0
make the changes marked in bold:
ISP#sh run
Building configuration...
Current configuration : 762 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ISP
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface Loopback0
ip address 8.0.0.1 255.255.255.255
interface GigabitEthernet0/0/0
ip address 100.0.0.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
R1#sh run
Current configuration : 1085 bytes
version 15.4
hostname R1
no ip cef
no ipv6 cef
ip address 10.30.30.1 255.255.255.0
--> ip nat inside
duplex auto
speed auto
ip address 192.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
media-type sfp
ip address 100.0.0.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.30.30.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 1
--> default-information originate
ip nat inside source list 1 interface GigabitEthernet0/0/2 overload
ip classless
ip route 0.0.0.0 0.0.0.0 100.0.0.2
ip route 10.10.2.0 255.255.255.0 192.168.10.2
--> access-list 1 permit 10.0.0.0 0.255.255.255
--> access-list 1 permit 192.168.10.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Hello
The reason NAT isnt working is due to the fact RTR2/4 dont have any default route for off site destinations if you advertise a default from RTR 1 into the network for RTR2/4 then it will work
Also Relocate the ACL 100 onto RTR4 and just deny specifically icmp echo and echo-reply
Kind Regards
Paul
