Pause input and flow control
mohammedrafiq
I am having issue on my 3750G gig interface, it is not passing data more than 200M.Some how its giving me lots of input Pause on both sides,can some one explain if there is congesstion issue,do I need to enable flow control on both sides?
regards,
-1#sh interface GigabitEthernet1/0/25
GigabitEthernet1/0/25 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0019.2f7f.5919 (bia 0019.2f7f.5919)
Description: LES link to TeleHouse
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 17/255
Keepalive not set
Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported <----------------------?
Last input never, output 00:00:58, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 69442000 bits/sec, 22986 packets/sec
2039460396 packets input, 1512854019 bytes, 0 no buffer
Received 11 broadcasts (0 multicast)
0 watchdog, 0 multicast, 124553349 pause input <--------------------issue ?
208502459 packets output, 2269043255 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 output buffer failures, 0 output buffers swapped
Danilo Dy
The interface keepalive is not set. Your interface maybe up/up but it could be spoofing. Set the interface keepalive to 10 seconds
Dandy
thanks,I will set the keepalive to 10 sec, but the interface is always up and passing data all the time, I am worried why its showing lots of input pause ?
Let us know what is connected to this gig interface.
To slow down the received traffic rate, that end device is sending the pause signal to this port, indicating the port to slow down/pause the traffic.
There is nothing wrong with this switch port. Enable the input flow control at this port if possible and observe the results.
Hope this helps.
-VJ
Have you solved your issue?
I am having the same problem.
Rodrigo
