Pb DSL line ROUTER 2801
hassanimagid
I have a pb withe my WIC ADSL.
When I connect to the DSL line It give thet not ok.
I have on this router a T1 line that is ok.
And I want that the DSL line like Backup.
I give you my running conf.
Could you please tell me what is the pb about my wicADSL.(what i forgot)
In advance thanks
Building configuration...
Current configuration : 4602 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxxx
no aaa new-model
resource policy
clock timezone PCTime 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip name-server 212.x.0.1
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-369948791
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-369948791
revocation-check none
rsakeypair TP-self-signed-369948791
crypto pki certificate chain TP-self-signed-369948791
certificate self-signed 01
3082024B ......(number)....... FD0828
quit
username admin privilege 15 secret xxxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
ip address X.X.X.X 255.255.255.252 secondary
ip address Y.Y.Y.Y 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.3 point-to-point
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Serial0/2/0
ip address Z.Z.Z.Z 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface Dialer0
ip address dhcp client-id FastEthernet0/1
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname cccccccccccc
ppp chap password 7 cccccccccccc
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/2/0
ip route 0.0.0.0 0.0.0.0 Dialer0 250
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
access-list 2 remark SDM_ACL Category=2
access-list 2 permit S.S.S.S 0.0.0.15
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
hassanimagid
Please help me!!!
wochanda
Level 4
Level 4
Config looks good, please post the following:
'show interface a0/1/0'
'show atm pvc 8/35' (have you tried 0/35 instead?)
'show ip interface brief'
If you see a virtual-access interface coming up and down in your logs, it means you got all of the ATM stuff right, but PPP isn't coming up (usually due to authentication). If this is the case, please paste in a 'debug ppp negotiation'
If you aren't seeing this, try a 'debug vpdn pppoe-events'
Check out the following doc, it has a great set of steps to check on troubleshooting a PPPoEoA connection:
http://www.cisco.com/warp/public/794/adslguide_pppoedsl_ts.shtml
You're right the conf is ok. because when I ping with SDM the ISP DNS it's ok. But the clients haven't internet.
Hello, I have a router 2801 with a Wic 1T and a WIC ADSL. I have configure them and it's ok. With the wic 1T I arrive has to connect me on Internet and exchange OK(son addresses external is X.X.X.X).
With WIC ADSL, I ping with tool SDM towards the exterior, but I do not have Internet at my clients(my addresses external is an address negocieted Z.Z.Z.Z).
The problem is on the level of my addresses because there is reserve 2 beach of address 16 adresses(Y.Y.Y.Y) and 4(W.W.W.W) which are configured in my interface ethernet0.
My question is that I do not know how to make so that my ADSL points towards addresses Y.Y.Y.Y as from the serial.
Or I must configure my interface ethernet1 with a part of my beach of adresses(Y.Y.Y.Y)?
Help me please?
I have a little difficulty to understand Here my code if that can you help at the next post
Sorry, I want that the adsl like backup
My conf
Current configuration : 4582 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret xxxx
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip name-server 212.217.0.1
ip ssh time-out 60
3082024B <> FD0828
quit
username admin privilege 15 secret 5 $1$Uk3Y$Z4Co8lP2/hMrnWs.sLtWh.
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip address W.W.W.W 255.255.255.252 secondary
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface ATM0/1/0.1 point-to-point
pvc 8/35
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname ::::::::
ppp chap password 7 :::::::::
ip classless
ip http server
access-list 2 permit !!!!!! 0.0.0.15
no cdp run
control-plane
line con 0
login local
line aux 0
login local
line vty 0 4
privilege level 15
login local
line vty 5 15
privilege level 15
login local
end
