PBR and NAT inbound
Junior Mateus
Hello Everybody,
I´m a new in a routing environement particulary for PBR mechanisme :
here is the scenario :
i have one RT connecting to 2 ISP :
ISP1 : 41.218.114.85
ISP2: 41.63.166.254
interface GigabitEthernet0/0
description LINK-TO-LAN(ASA)
ip address 10.30.21.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip policy route-map concerned-traffic
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description RESERVED TO ISP1(ITA)
ip address 41.218.114.86 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat outside
ip verify unicast source reachable-via rx allow-default 100
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
description RERSERVED-ISP2(Tvcabo)
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no mop enabled
ip route 0.0.0.0 0.0.0.0 41.63.166.254 254
ip route 0.0.0.0 0.0.0.0 41.218.114.85 255
ip route 10.0.0.0 255.0.0.0 10.30.21.2
ip route 172.30.0.0 255.255.0.0 10.30.21.2
Objective :
1. Use the ISP for Critical traffic : Telnet, SSH, MAIL(smtp,pop3,imap) and VPN
2.Use the ISP2 for All of the reste of Traffic : HTTP.HTTPS,FTP,....
3. All Traffic for External Users (outside) have to be Nating to  ISP1 interface, example https of internal web server, ftp server..
Doing :
(1-2) i have create an acl for critical Traffic and a route-map  as :
ip access-list extended WEB-ACCESS
permit ip any any
ip access-list extended critical-traffic
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit udp any any eq 10000
permit tcp any any eq smtp
permit tcp any any eq pop3
permit tcp any any eq 143
permit tcp any any eq 993
permit tcp any any eq 587
permit tcp any any eq telnet
permit tcp any any eq 22
route-map concerned-traffic permit 10
match ip address critical-traffic
set ip next-hop 41.218.114.85
route-map concerned-traffic permit 20
set ip next-hop 41.63.166.254
i have applied it to the LAN interface
wich route all the critical traffic to the ISP1 and all of the rest to ISP2
(3) for permit my internal LAn to have access to the internet i have use the nat overload and create 2 route map :
route-map WEB-ISP2 permit 10
match ip address WEB-ACCESS
match interface GigabitEthernet0/2
route-map WEB-isp1 permit 10
match interface GigabitEthernet0/1
ip nat inside source route-map WEB-ISP2 interface GigabitEthernet0/2 overload
ip nat inside source route-map WEB-isp1 interface GigabitEthernet0/1 overload
(4)  Difficulties that i meet :
this operation work well when i´m inside the network mean, in the LAN
but i have a big difficulties to set the inbound nat for https , VPN,...
ip nat inside source static tcp 10.30.21.2 21 41.63.166.15 21 extendable
ip nat inside source static tcp 10.30.21.2 22 41.218.114.86 22 extendable
ip nat inside source static tcp 10.30.21.1 23 41.218.114.86 23 extendable
ip nat inside source static tcp 10.30.21.2 443 41.218.114.86 443 extendable
ip nat inside source static udp 10.30.21.2 500 41.218.114.86 500 extendable
ip nat inside source static udp 10.30.21.2 4500 41.218.114.86 4500 extendable
ip nat inside source static udp 10.30.21.2 10000 41.218.114.86 10000 extendable
when i try  with the IP of the interface ISP1 (41.218.114.86) to reach an inside server via static nating, i´m not able
Maybe my configuration are wrong ? i need your help guys , please help me
thank u in Advance
0 Replies 0
