10-05-2005 07:50 AM - edited 03-03-2019 10:40 AM
We have two WAN links thro different ISP's and both are terminating in two separate Routers ( R1 & R2) . The ethernet Interfaces of R1 & R2 are connected in a Switch and we added R1 ethernet IP address range as secondary IP address in other Router's ethernet interface (R2) and implemented PBR in R2 . The next hop address in R2 points R1 ethernet primary IP address . Can we implement PBR in two separate Routers connected in this way ?.
Appreciated for your reply.
Raju
10-05-2005 08:07 AM
That should work. The question is why do you want PBR to function this way. What are you trying to do ?
10-05-2005 08:23 PM
Thanks. The primary reason is, we don't want disturb the existing setup (Two Routers) and we don't want to do any investments i.e buying WAN card .
