PBR next hop
Farhan Shaikh
Hi All,
Can any 1 explain me the below command.
set ip next-hop 115.114.57.241 192.168.5.1
I am using PBR here i need to set the next hop. As per my understanding the next hop specified is 115.114.57.241. Then waht is the second ip address used for.
Thanks in advance.
Jon Marshall
The second IP address is used if the first is not reachable.
Jon
Jon Marshall
Jon
Thanks Jon..
Hello
FYI
the second next hop address will NOT be used unless you verify the availably in the PBR route-map
One a match is made in the route-map the router will continue to try and PBR to the first address even if that next hop is unreachable.
The following command validate those next hops.
Route-map xxx
set ip next-hop verify-availability
Please review this
http://www.cisco.com/c/en/us/td/docs/ios/iproute_pi/command/reference/iri_book/iri_pi2.html#wp1012541
Res
Paul
Kind Regards
Paul
