PBR on BGP-running router
nika qutidze
We have dual-homed cisco 3945E router, both ISP gives us default route + specific routes. Default route from onr of the ISP is installed in RIB using BGP weight preference.
We are using PBR on inside interface and with another next-hop, but traffic always follows BGP injected default route.
If there some restriction of using PBR on BGP-running router???
Jose Jara
Level 3
Level 3
please, post the configuration.
Jose.
milan.kulik
Level 10
Level 10
there should not be.
Are you sure the next-hop is reachable?
Can you provide more details how you PBR is configured?
Best regards,
Milan
