PBR Problem
atiye.bigdeli
Level 3
Level 3
Hi friends.
We have 2 ISP and now we use only isp 1 for forwarding traffic and the isp 2 is for backup.
we decided to forward some traffic toward isp 2 using pbr,
also we have dmvpn for all branch,
we have a problem with pbr and it does not forward the traffic toward the second link.
my access-list and the pbr policy matches.
Extended IP access list Antivirus_To_Branch2
10 permit ip host 172.30.111.88 10.113.1.128 0.0.0.127 (62934 matches)
route-map Backup_Link permit 2
match ip address Antivirus_To_Branch2
set ip next-hop 10.198.198.130
sho route-map Backup_Link
route-map Backup_Link, permit, sequence 1
Match clauses:
ip address (access-lists): Antivirus_To_Branch2
Set clauses:
Policy routing matches: 63320 packets, 40651445 bytes
 when I use the debug command " debup ip policy"
I got this error
CEF-IP-POLICY: fib for addr 10.198.198.130 is Not Attached; Nexthop rejected
what is the problem? the second link is connect.
best regards
7 Replies 7
Georg Pauwen
is 10.198.198.130 a directly connected next hop ? Post the full configuration of your router...
Hi and thank you for answer.
hub config
int tu 3
ip adress 10.198.198.129 255.255.128
tu des mode multipoint
tu source int gi0/1.100
int gi 0/0
ip policy route-map backup_link
antvirus_To_Branch2
spoke that is the next hop
int t 3
ip address10.198.198.130 255.255.255.128
the two interface are dmvpn interfaces that have connectivity through WAN MPLS
best regards
change your set clause to:
set interface Tunnel 3
Hello
just like to add - suggest to apply some validation of availability for the  nexthop  otherwise if it become unavailable you will incur blackholing of what ever is being pbr’d
Set ip next-hop verifiy availability x.x.x.x track x
Kind Regards
Paul
thank you for your help and answer
is there no problem with adding the multipoint dmvpn interface in the " set interface " command?
can the router decide the correct destination?
when I set the dmvpn interface I received this error.
%Warning:Use P2P interface for routemap setinterface clause
and it does not work
best regards
Hello
Did you set the next hop towards the NBMA address of the DMPN spoke?
Kind Regards
Paul
No I dont set the NBMA address I set the tunnel address as the next hop.
is that correct?
best regards
