PBR question
VONGJOYCE
I would like to ask if it is possible to set the next hop to be an adjacent router interface that is not directly connected with the policy router? That means in router 1, I want to apply a PBR to set the next hop to be router 2 serial interface instead of LAN interface. Router 1 and Router 2 are connected to same LAN interface with its own WAN serial interface.
I think this won't work as it seems the next hop has to be a subnet that both routers sharing so the serial address in Router 2 as next hop won't work. I am hoping if there is anyway to get around it, otherwise I will have a blackhole situation that if Router 2 serial goes down, the PBR still continue to send traffic to Router 2 LAN interface and get blackhole afterwards.
Thank you.
2 Accepted Solutions
Joyce,
Actually, PBR does allow you to use a next-hop that's not directly connected when you use the keyword 'recursive' in the 'set ip next-hop' command. If the recursive next-hop you specified becomes unavailable the router would route the traffic using the default route, if one is configured.
See more info here:
http://www.cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a0080457b9c.html#wp1048914
Sundar
vladrac-ccna
Level 5
Level 5
As far as I remmember, yes this is possible.
PBR Recursive Next Hop
The PBR Recursive Next Hop feature enhances route maps to enable configuration of a recursive next-hop IP address that is used by policy-based routing (PBR). The recursive next-hop IP address is installed in the routing table and can be a subnet that is not directly connected. If the recursive next-hop IP address is not available, packets are routed using a default route.
check this link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hirp_c/ch20/h_12spbr.htm#wp1027188
Vlad
Joyce,
See more info here:
Sundar
Thank you very much Sundar and Vlad for your great tip. This is exactly what I need. Thank you very much!
vladrac-ccna
Level 5
Level 5
check this link:
Vlad
