PBR - Questions
Thiago Cella
Hi Friends,
Imagine the simple scenario, with interface inside to lan address, and two ISP links. I would like to know, if is possible, the follow situations, and please could you send the examples and articles explain how to do this, using router Cisco, with IOS universal:
Questions:
From inside all traffic with protocols HTTP,HTTPS,ICMP, uses the ISP1
From inside all traffic with protocols FTP, uses the ISP2
When the ISP1 is down, the traffic HTTP,HTTPS,ICMP  use the ISP2
When the ISP2 is down, the traffic FTP use the ISP1
In the same scenario, there is a NAT to address from outisde access my server on port 3389, simultaneously by ISP1 and ISP2.
Tks
Terence Payet
Yes you can, by using ip sla with track objects + your PBR config.
See below example:
ip sla1
icmp-echo 8.8.8.8 source-interface -> facing ISP1
frequency 10
ip sla 1 schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface -> facing ISP2
frequency 10
ip sla 2 schedule 1 life forever start-time now
track 1 rtr 1 reachability
track 2 rtr 2 reachability
ip access-list extended ISP1_TRAFFIC
permit tcp LAN address any eq 80
permit tcp LAN address any eq 443
permit icmp LAN address any
p access-list extended ISP2_TRAFFIC
permit tcp LAN address any eq 20
permit tcp LAN address any eq 21
route-map ISP1_MAP permit 10
match ip address ISP1_TRAFFIC
set ip next-hop verify-availability 'ip next hop of ISP 1'  track 1
route-map ISP2_MAP permit 10
match ip address ISP2_TRAFFIC
set ip next-hop verify-availability 'ip next hop of ISP 2'  track 2
Now apply the route-map to the respective interfaces.
HTH.
Please rate helpful post.
Terence
Tks tpayet120 ,
But if ISP1 is down, the traffic http,https and icmp will work ISP 2?
And the ISP2 is down, the FTP goes to ISP1?
And the static nat, work simultaneously  with two ISP?
t
