PBR-Route-map match track
I have question about match track please , i have understand ,if track is up ,it execute the follwoed set command ,if down ,it comes automaticaly to the second section of the Route-map ,is my Understanding true please ? . In my Lab ,even if it is down ,the set command executed ,and it come not to the next section 30 ,my route-map is:
route-map GLOBAL_TO_VRF permit 20
match track 6
set ip default next-hop 10.10.10.1
route-map GLOBAL_TO_VRF permit 30
set VRF A
with track 6 ,i have routing reachabilty with IPsla, but even if it's down ,it does't com  to step 30 (set vrf A) ,it comes from Global default to next hop 10.10.10.1 but without vrf A , can you please explain me why .i tried  the default , in the set ip ,to skip and i applied also in both steps(20&30) match ACL extra  , it stay with the same next hop condition 10.10.10.1 with up and down track ,and come never to  sec 30  !? Thank you very much for your help
that is my Topology
16 Replies 16
@dunya Abdulrazzaq
 How did you configure the IPSLA and the track. Can I see the whole config?
You need something like   " track X ip sla x reachability"
and something like
set ip next-hop verify-availability x.x.x.x  X  track X
For what ypu want this pbr ??
MHM
as reliability option in WAN connection , i have it as LAB ,i have in my Topology 3 Routers ,and i want to configure redundancy Option using VRF-Lite between the 3 Routers ,in each router ,i have VRF A neben Global Routing bei each Router with the same IP  ,if the main interface in Global go Down , the other interface in VRF wird active for trafiic , i have made Leak between VRF and Global tabel ,and the routing works good beetwen them  . till now its works , but i am wunder about  match Track !!,why it give me no skip bei down
Thank you for answer ,IPSLA works good ,it is :
ip sla 6
icmp-echo 10.10.10.1 source-interface Ethernet0/1
ip sla schedule 6 life forever start-time now
track 6 ip sla 6 reachability .
and it give down ,if the connection also down
*the"set ip next-hop verify-availability x.x.x.x  X  track X " i used with the mittel Router instead of match track ,and it works  good , i don't need hier match track but match ACL .and it track the connection ok and the PBR works fine ,to explain i have in topology 3 Routers .But my Question was about match track ,because i need it in the 2 Side Routers ,with others command .hier i have problem with route-map 30 , i bekome o packets ,wheather Track 6 in route-map 20 Up or down .
PBR for routing dont check line 30 since it dont have match condition.
and again for which this PBR use for ?
MHM
i tried it also with match ACL ,in both 20 and 30 , and it also the same Output
you use set vrf so I need to know topolog and for what this PBR use for
MHM
Hello
The assumption here is you are using PBR with that route-map in a vrf?
if so then stanza 30 is NOT applicable as the route-map will be called by the interface the policy is applied and as it states vrf then again the assumption is that interface is already associated within the vrf
As for the ipsla tracking i would suggest track reachability for the isla and not ip routing
track x rtr x reachability
ip route vrf xx (tracked ip) global
route-map xx
(match what traffic you wish to pbr via a acl or prefix-list or have no match so all traffic originating from the interface will be policy routed)
set ip next-hop verify-availability 10.10.10.1 1 track x
interface xxx
Ip vrf forwarding xx
Ip policy route-map xxx
Kind Regards
Paul
thank you Paul for your Answer ,but the interface, which this policy applied on  , is not associated with any vrf , it is the LAN to the Router  Ingress ,it is part from Global Tabel direct connected Network .
i have this Topology
bei each the sides Routers R7,R5 ,i have two output Interfaces (with the same IP ),one belong Global Tabel ,one belong VRF , i have configured leak(using Recieve VRF) between the Global and the VRF ,there is ein static Route from the Global to the VRF A . My Senario , if the main Link (Global Link) go down , the LAN traffic to the main SITE und other Branch will be forwarded usin PBR to the other WAN LInk(VRF LINK)  ,till now ,it work ok , bei the middel Router ,i used "set ip next-hop verify-availability x.x.x.x  X  track X" ,and even with 2 sides Routers , the "set Ip default ip next-hop " works also fine ,and the LAN traffic will be forwarded using static Router from Global to the VRF A and reach the otherside , but to my Understanding , i want to see the effect of setting the o/p packet from Global  with VRF A Tag ,bei Down Interface , because in the middel i have to use set VRF A in PBR (bei Fall Down Int) , in the 2 Side Router ,it works fine ,und that make me Confused ,do i need bei LEAKING from GLOBAL to VRF ,a VRF Tagged Packet oder not , i wanted that using Debag to see , and i use the"Match track" with down " Set VRF" to see the difference . But with the Match track   i come always to next-hop without VRF !. I hope i could explain my Seniario good , but the relability Senario  between the 3 LANS works ok ,and i have connectivity between the 3 Lans ,even with the Global WAN DOWN ,it works good ,i assume using LEAKING and staic Routing .
i have applied  the Toplpgy to the LAN Interface (INcoming Traffic to the router from the LAN ) ,und this Interface has no VRF ,it belong to the Global Routing
Ok' let me check solution I will update you soon
MHM
Configured leak(using Recieve VRF) between the Global and the VRF <<- can I see how you config the leaking
MHM
Thank you for your Answer ,
the Design simply , a Redundacy option using VRFLite ,  i use it for the WAN Link(betwen the 3 Office) and also for VPN LINK (between the site Office) , if the main Link(Global RT) falldown(also with the IPSEQ Tunnel 2) , come the other Link with same IP (and the other IPSEQ Tunnel 1) as active Link
the design seem to work fine ,but my Question was mainly  about the Track,even when it is down ,the route-map execute the seq . and i had some Confusion about set Global ,set VRF  command , if we should  use it or not ,in such design ,so can the traffic recognized from Global RT, and VRF RT,vice versa.but obvasily in this design ,that is not recuried ,it seems to work fine through ,static  and redistributed Routing
I will be thankfull for your Advice , it is only Virtuell Project
hier is the Configuration :
R7 Site Router Office 1
ip vrf A
rd 1:1
#VPN Connection from Office 1 to Office 2
interface Tunnel1
ip vrf forwarding A
ip address 192.168.100.2 255.255.255.0
keepalive 5 4
tunnel source Ethernet0/0
tunnel destination 20.20.20.2
tunnel vrf A
interface Tunnel2
keepalive 5 4
tunnel source Ethernet0/1
#WAN Connection to HQ (R9)
interface Ethernet0/0
ip vrf forwarding A
ip address 10.10.10.2 255.255.255.0
crypto map VPN-A
crypto map VPN
#Connection to the LAN Office 1
interface Ethernet0/2
ip vrf receive A ### Receive Command
ip address 50.50.50.1 255.255.255.0
ip policy route-map GLOBAL_TO_VRF_OR_R5-VPN #PCR Policy with next-hop and Tunnels Redundancy
router ospf 1 vrf A
redistribute connected subnets
network 10.10.10.0 0.0.0.255 area 0
network 192.168.100.0 0.0.0.255 area 0
router ospf 3
network 50.50.50.0 0.0.0.255 area 0
ip route 10.10.10.0 255.255.255.0 Ethernet0/0 #static route to vrf A
ip route vrf A 40.40.40.0 255.255.255.0 Tunnel1 #static route to GRE Tunnel 1 in VRF A
ip access-list extended ACL1 #ACL für IPSEQ VPN
permit gre 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
ip access-list extended VPN
permit ip any 40.40.40.0 0.0.0.255
ip sla 6
route-map GLOBAL_TO_VRF_OR_R5-VPN permit 10 #Route map for IPSEQ VPN Tunnel Redundancy
match ip address VPN
set interface Tunnel2 Tunnel1
route-map GLOBAL_TO_VRF_OR_R5-VPN permit 20 #Route map for WAN Redundancy
match track 6
set ip default next-hop 10.10.10.1 auf Global RT ,it is the direct connected Link e0/1,if down ,go to the next (static to the vrf A ,next WAN connection e0/0,(don't need "set VRF A")
show ip Route ### Global RT
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, Ethernet0/1
L 10.10.10.2/32 is directly connected, Ethernet0/1
20.0.0.0/24 is subnetted, 1 subnets
O 20.20.20.0 [110/20] via 10.10.10.1, 00:20:57, Ethernet0/1
40.0.0.0/24 is subnetted, 1 subnets
O 40.40.40.0 [110/30] via 10.10.10.1, 00:20:57, Ethernet0/1
50.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 50.50.50.0/24 is directly connected, Ethernet0/2
L 50.50.50.1/32 is directly connected, Ethernet0/2
O 192.168.52.0/24 [110/20] via 10.10.10.1, 00:20:57, Ethernet0/1
192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.100.0/24 is directly connected, Tunnel2
L 192.168.100.2/32 is directly connected, Tunnel2
show ip Route vrf A
C 10.10.10.0/24 is directly connected, Ethernet0/0
L 10.10.10.2/32 is directly connected, Ethernet0/0
O 20.20.20.0 [110/20] via 10.10.10.1, 00:22:53, Ethernet0/0
S 40.40.40.0 is directly connected, Tunnel1
O E2 192.168.52.0/24 [110/20] via 10.10.10.1, 00:22:53, Ethernet0/0 #redistribute from Neighbor R6
C 192.168.100.0/24 is directly connected, Tunnel1
L 192.168.100.2/32 is directly connected, Tunnel1
R5 Site Router -office 2
ip vrf A
rd 1:1
#VPN Connection from Office 2 to Office 1
interface Tunnel1
ip vrf forwarding A
ip address 192.168.100.1 255.255.255.0
keepalive 5 4
tunnel destination 10.10.10.2
tunnel vrf A
interface Tunnel2
keepalive 5 4
ip vrf forwarding A
ip address 20.20.20.2 255.255.255.0
crypto map VPN-A ##IPSEC Crypto Policy -VRF A
crypto map VPN ##IPSEC Crypto Policy -Global RT
interface Ethernet0/2 #Connection to the LAN Office 2
ip vrf receive A
ip address 40.40.40.1 255.255.255.0
ip policy route-map GLOBAL_TO_VRF_OR_R7-VPN #PCR Policy with next-hop and Tunnels Redundancy
router ospf 1 vrf A
network 20.20.20.0 0.0.0.255 area 0
router ospf 3
network 40.40.40.0 0.0.0.255 area 0
ip route 20.20.20.0 255.255.255.0 Ethernet0/0 #static route to vrf A
ip route vrf A 50.50.50.0 255.255.255.0 Tunnel1 #static route for GRE Tunnel 1
ip access-list extended ACL1 #ACL for GRE Traffic
permit gre 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip any 50.50.50.0 0.0.0.255
access-list 2105 permit ip 40.40.40.0 0.0.0.255 any
ip sla 3
icmp-echo 20.20.20.1 source-interface Ethernet0/1
ip sla schedule 3 life forever start-time now
route-map GLOBAL_TO_VRF_OR_R7-VPN permit 10 #Route map for IPSEQ VPN Tunnel Redundancy ,the same princepe of R7 but hier i used default ,when the default(Tunnel2) not active Tunnel 1 will be used
set default interface Tunnel1
route-map GLOBAL_TO_VRF_OR_R7-VPN permit 20 #Route map for WAN Redundancy
match track 3
set ip default next-hop 20.20.20.1
#i have this als option instead of match track ,it works also ####
#match ip address 2105
set ip next-hop verify-availability 20.20.20.1 20 track 3 # it is the direct connected Link e0/1,if down go to the next (static to the vrf A ,next WAN connection e0/1)
set ip next-hop 20.20.20.1
show ip Route
10.0.0.0/24 is subnetted, 1 subnets
O 10.10.10.0 [110/20] via 20.20.20.1, 00:59:59, Ethernet0/1
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 20.20.20.0/24 is directly connected, Ethernet0/1
L 20.20.20.2/32 is directly connected, Ethernet0/1
40.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 40.40.40.0/24 is directly connected, Ethernet0/2
L 40.40.40.1/32 is directly connected, Ethernet0/2
50.0.0.0/24 is subnetted, 1 subnets
O 50.50.50.0 [110/30] via 20.20.20.1, 00:59:59, Ethernet0/1
O 192.168.52.0/24 [110/20] via 20.20.20.1, 00:59:59, Ethernet0/1
L 192.168.100.1/32 is directly connected, Tunnel2
show ip Route vrf A
O 10.10.10.0 [110/20] via 20.20.20.1, 01:01:05, Ethernet0/0
C 20.20.20.0/24 is directly connected, Ethernet0/0
L 20.20.20.2/32 is directly connected, Ethernet0/0
S 50.50.50.0 is directly connected, Tunnel1
O E2 192.168.52.0/24 [110/20] via 20.20.20.1, 01:01:05, Ethernet0/0
L 192.168.100.1/32 is directly connected, Tunnel1
*show Ip int brief of R5
R9 HQ router
ip vrf A
rd 1:1
track 3 ip sla 3
track 4 ip sla 4
Connection to R5
ip vrf forwarding A
ip address 20.20.20.1 255.255.255.0
#Connection to R7
interface Ethernet1/0
ip vrf forwarding A
ip address 10.10.10.1 255.255.255.0
interface Ethernet1/1
interface Ethernet0/2 #Connection to the HQ LAN
ip vrf receive A **
ip address 192.168.52.100 255.255.255.0
router ospf 1 vrf A
router-id 4.4.4.4
router ospf 3
router-id 9.9.9.9
network 192.168.52.0 0.0.0.255 area 0
ip sla 3
icmp-echo 10.10.10.2 source-interface Ethernet1/1
ip sla 4
icmp-echo 20.20.20.2 source-interface Ethernet0/1
ip sla schedule 4 life forever start-time now
route-map GLOBAL_TO_VRF permit 10 ### Route-map to set the next-hop to R5
match ip address 2107
set ip next-hop verify-availability 20.20.20.2 10 track 4 #### auf Global RT ,it is the direct connected Link e0/1,if down go to the next (static to the vrf A ,next WAN connection e0/0)
set ip vrf A next-hop 20.20.20.2
##or set ip next-hop 10.10.10.2
route-map GLOBAL_TO_VRF permit 20 ### Route-map to set the next-hop to R7
match ip address 2117
set ip next-hop verify-availability 10.10.10.2 20 track 3 ##auf Global RT ,it is the direct connected Link e1/1,if down go to the next (static to the vrf A ,next WAN connection e1/0)
##or set ip vrf A next-hop 10.10.10.2 ##the same
#traffic to the R5 site
access-list 2107 permit ip any 40.40.40.0 0.0.0.255
access-list 2107 permit ip any 20.20.20.0 0.0.0.255
#traffic to the R7 site
access-list 2117 permit ip any 50.50.50.0 0.0.0.255
access-list 2117 permit ip any 10.10.10.0 0.0.0.255
#if you want to setup the PDR Policy as Local Router Policy ,the ipsec traffic muss excluded from policy in all 3 Routers
for example in HQ
access-list 2107 deny ip 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 2117 deny ip 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
show ip route
C 10.10.10.0/24 is directly connected, Ethernet1/1
L 10.10.10.1/32 is directly connected, Ethernet1/1
L 20.20.20.1/32 is directly connected, Ethernet0/1
O 40.40.40.0 [110/20] via 20.20.20.2, 01:44:00, Ethernet0/1
O 50.50.50.0 [110/20] via 10.10.10.2, 01:44:00, Ethernet1/1
192.168.52.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.52.0/24 is directly connected, Ethernet0/2
L 192.168.52.100/32 is directly connected, Ethernet0/2
O 192.168.100.0/24 [110/1010] via 20.20.20.2, 01:43:37, Ethernet0/1
[110/1010] via 10.10.10.2, 01:43:37, Ethernet1/1
show ip route vrf A
C 10.10.10.0/24 is directly connected, Ethernet1/0
L 10.10.10.1/32 is directly connected, Ethernet1/0
L 20.20.20.1/32 is directly connected, Ethernet0/0
O E2 40.40.40.0 [110/20] via 20.20.20.2, 01:44:38, Ethernet0/0
O E2 50.50.50.0 [110/20] via 10.10.10.2, 01:44:38, Ethernet1/0
O 192.168.100.0/24 [110/1010] via 20.20.20.2, 01:44:15, Ethernet0/0
[110/1010] via 10.10.10.2, 01:44:15, Ethernet1/0
hier is the RT with offline link :
R5
for R7
for R9-HQ
Tunnel 1&Tunnel2 Reduncy
sample von debug ip policy of R9
*please notice if you want to test it ,test the Connectivity from the Switches ,because bei Fall down the Link ,you need for the local traffic from the Router , to setup Local PBR , and the traffic related the Ipseq muss be excluded from Route-map with deny (between 10.10.10.0 und 20.20.20.0) , i let you one as ex .i have tested locally .und it works, but hier in this configuration without local PBR
the tunnel destiation for tunnel is not direct connect ? why you use 20.20.20.x instead of using 10.10.10.x ?
the subnet 20.20.20.x or 10.10.10.x must be global RIB in both tunnel head
MHM
