PBR-Route-map match track
I have question about match track please , i have understand ,if track is up ,it execute the follwoed set command ,if down ,it comes automaticaly to the second section of the Route-map ,is my Understanding true please ? . In my Lab ,even if it is down ,the set command executed ,and it come not to the next section 30 ,my route-map is:
route-map GLOBAL_TO_VRF permit 20
match track 6
set ip default next-hop 10.10.10.1
route-map GLOBAL_TO_VRF permit 30
set VRF A
with track 6 ,i have routing reachabilty with IPsla, but even if it's down ,it does't com  to step 30 (set vrf A) ,it comes from Global default to next hop 10.10.10.1 but without vrf A , can you please explain me why .i tried  the default , in the set ip ,to skip and i applied also in both steps(20&30) match ACL extra  , it stay with the same next hop condition 10.10.10.1 with up and down track ,and come never to  sec 30  !? Thank you very much for your help
that is my Topology
16 Replies 16
 the 2 tunnels between R7 and R5 , 20.20.20.2 is the R5 interface to the WAN  , in Draw i forgot the other side IPs of R5 ,sorry for make you confuse .i update it now
