PBR to select a specific service provider
moataz_mamdouh
I want to use PBR with route map to match some traffic coming from different vlans to go to a specific service provider I have vlan 10 and vlan 20 , both vlan default gateway are on the core switch I am thinking of configuring a route map to match source vlan 10 and set ip next hop to be the inside interface for the router to provider A Then i need to configure a PBR under interface but i am confused about which interface i have to apply the route map , is it the vlan interface on the core switch ? Also i need to know who can i test it
Hi ,
 What is your core switch hardware ?? , need to verify do it support PBR . Share me your switch config and next hop ip address of your both service provider .
Sandy
