PBR Using Tracked BGP Route
helenofagundes
Hello Guys,
My scenario is:
2 Sites interconnected by 2 MPLS Links and BGP between the routers.
I need some help to force some traffic to be routed using one Link based on Protocol or TCP Port.
But if the link goes down, I need the traffic to be send using another link.
I want to do a PBR using track that validates a specific BGP Route or BGP Neighbor.
Can someone tell me some tips for this case?
Best Regards.
Heleno Fagundes
5 Replies 5
hkkalra
For your two concerns.
**2 Sites interconnected by 2 MPLS Links and BGP between the routers
 Do you have some sort of network diagram ????
**I want to do a PBR using track that validates a specific BGP Route or BGP Neighbor.
We can always apply a track and an IP sla monitoring an IP address which the router is receiving from its BGP peer which you wish to monitor.
I am sure if you provide me sample diagram/config i'll be able to give some more descriptive answer.
HK
Attached the Topology as you asked.
I would like to track the BGP Route, I do not want to trust in a ICMP Ping with SLA to track reachability of the neighbor.
If the neighbor loss the route and stop to announcing in BGP, my track using ICMP will continue OK, but the route is not in the table.
Because of that I need to use a PBR Working with BGP.
Is that possible?
Best Regards.
Heleno Fagundes
Hello
How are these peers connecting? - directly or logical? - I mean are they peering from a source logical ip address ( loopback) and LB over one ip address or are do you have two direct ebgp peers using the physical interfaces?
I assume you aslo have maximum paths configured?
FYI - PBR with tracking on the line protocol without ip sla would be an option or you may be able to use the bgp weight attribute.if applicable to your needs.
the latter would be something like this:
access-list 2 permit x.x.x.0 0.0.0.255
access-list 22 permit y.y.y.0 0.0.0.255
neighbor 10.0.0.1 route-map weight2 in
neighbor 10.0.1.1 route-map weight in
router bgp 65501
route-map weight2 permit 10
 match ip address 2
 set weight 30000
route-map weight2 permit 90
 set weight 25000
route-map weight22 permit 10
 match ip address 22
 set weight 30000
route-map weight22 permit 90
 set weight 25000
The alternate applied to the other router also.
res
Paul
Kind Regards
Paul
Hi Paul,
My BGP Peers are using the IP of Physical Interface and they are logically connected, not a Direct link...
I need to make a decision of routing based on the protocol of application(TCP/1494 for instance) and not based on IP Address.
I have many servers using this type of connection and I need to choose que route based on TCP Port. The use of specific destinations based on IP it's hard and not an alternative for me.
Because of that I think that I have to use PBR. But the problem is the Track based on ICMP, I want to track an BGP route to validate the PBR "set ip next-hop" step.
Best Regards
Heleno Fagundes
The problem was solved using PBR with a Tracked object matching an IP Route /32 announced by the alternative BGP path.
Example:
track 1 ip route 1.1.1.1/32 reachability
route-map alpha permit 10
 match ip address 101
 set ip next-hop verify-availability 192.168.0.10 10 track 1
route-map alpha permit 20
More info:
http://www.cisco.com/c/en/us/td/docs/ios/12_2sb/feature/guide/sbaiptrk.html#wp1047054
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/sweot.html#wp1086250
Regards.
Heleno Fagundes
