PC can ping router but cannot ping a different network (Packet Tracer)
foolinartemis
I am doing a lab for class that's due at midnight tonight and I've been having trouble for the past couple of days. The assignment is to essentially create a topology with 4 different networks connected with 3 different routers. 3 of the networks have a switch, 5 PCs, and a server. I have been able to set it up to where my PCs can ping their own router, but they cannot ping another router or PC on another network. However, my routers can ping each other (at least on their connected interfaces). I tried to set up static ip routes, but I'm unsure if I did it correctly or not. I was given a network of 192.168.20.0/24 that I had to VLSM, and this is my topology table:
Device
Interface
IP Address
Subnet Mask
Default Gateway
R1
G0/0
192.168.20.1
255.255.255.192
R1
S0/0/0 (DCE)
192.168.20.145
255.255.255.252
R2
S0/0/0
192.168.20.146
255.255.255.252
R2
G0/0
192.168.20.65
255.255.255.224
R2
S0/0/1 (DCE)
192.168.20.149
255.255.255.252
R3
S0/0/1
192.168.20.150
255.255.255.252
R3
G0/0
192.168.20.97
255.255.255.224
R3
G0/1
192.168.20.129
255.255.255.240
S1 (58-hosts)
192.168.20.2
255.255.255.192
192.168.20.1
S1-PC1
Fa0/1
192.168.20.3
255.255.255.192
192.168.20.1
S1-PC2
Fa0/2
192.168.20.4
255.255.255.192
192.168.20.1
S1-PC3
Fa0/3
192.168.20.5
255.255.255.192
192.168.20.1
S1-PC4
Fa0/4
192.168.20.6
255.255.255.192
192.168.20.1
S1-PC5
Fa0/5
192.168.20.7
255.255.255.192
192.168.20.1
S2 (29-hosts)
192.168.20.66
255.255.255.224
192.168.20.65
S2-PC1
Fa0/1
192.168.20.67
255.255.255.224
192.168.20.65
S2-PC2
Fa0/2
192.168.20.68
255.255.255.224
192.168.20.65
S2-PC3
Fa0/3
192.168.20.69
255.255.255.224
192.168.20.65
S2-PC4
Fa0/4
192.168.20.70
255.255.255.224
192.168.20.65
S2-PC5
Fa0/5
192.168.20.71
255.255.255.224
192.168.20.65
S3 (15-hosts)
192.168.20.98
255.255.255.224
192.168.20.97
S3-PC1
Fa0/1
192.168.20.99
255.255.255.224
192.168.20.97
S3-PC2
Fa0/2
192.168.20.100
255.255.255.224
192.168.20.97
S3-PC3
Fa0/3
192.168.20.101
255.255.255.224
192.168.20.97
S3-PC4
Fa0/4
192.168.20.102
255.255.255.224
192.168.20.97
S3-PC5
Fa0/5
192.168.20.103
255.255.255.224
192.168.20.97
S3a (7-hosts)
192.168.20.130
255.255.255.240
192.168.20.129
Ubuntu Server (S1)
Fa0/20
192.168.20.8
255.255.255.192
192.168.20.1
Windows OS (S2)
Fa0/20
192.168.20.72
255.255.255.224
192.168.20.65
Kali-Linux (S3)
Fa0/20
192.168.20.104
255.255.255.224
192.168.20.97
I have primarily just been trying to get a PC on the R1 network to ping a PC on a R2 network, so I'm going to give the show commands for those two networks.
Here is sh run for Router1 (R1):
Router#sh run
Building configuration...
Current configuration : 839 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524O0HM-
spanning-tree mode pvst
interface GigabitEthernet0/0
 ip address 192.168.20.1 255.255.255.192
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/0/0
 ip address 192.168.20.145 255.255.255.252
 clock rate 2000000
interface Serial0/0/1
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
ip classless
ip route 192.168.20.148 255.255.255.252 192.168.20.146
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
Show ip route for Router1 (R1):
Router#sh ip rout
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     192.168.20.0/24 is variably subnetted, 5 subnets, 3 masks
C       192.168.20.0/26 is directly connected, GigabitEthernet0/0
L       192.168.20.1/32 is directly connected, GigabitEthernet0/0
C       192.168.20.144/30 is directly connected, Serial0/0/0
L       192.168.20.145/32 is directly connected, Serial0/0/0
S       192.168.20.148/30 [1/0] via 192.168.20.146
Show run for Router2 (R2):
Router#sh run
Current configuration : 836 bytes
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524K237-
 ip address 192.168.20.65 255.255.255.224
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 192.168.20.146 255.255.255.252
 ip address 192.168.20.149 255.255.255.252
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
ip classless
ip route 192.168.20.0 255.255.255.252 192.168.20.145
line con 0
line aux 0
line vty 0 4
 login
end
 Show ip route for Router2 (R2):
Router#sh ip ro
     192.168.20.0/24 is variably subnetted, 7 subnets, 3 masks
S       192.168.20.0/30 [1/0] via 192.168.20.145
C       192.168.20.64/27 is directly connected, GigabitEthernet0/0
L       192.168.20.65/32 is directly connected, GigabitEthernet0/0
L       192.168.20.146/32 is directly connected, Serial0/0/0
C       192.168.20.148/30 is directly connected, Serial0/0/1
L       192.168.20.149/32 is directly connected, Serial0/0/1
Show run for Switch1 (S1):
Switch#sh run
Current configuration : 1140 bytes
version 15.0
hostname Switch
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/2
interface Vlan1
 ip address 192.168.20.2 255.255.255.192
 shutdown
ip default-gateway 192.168.20.1
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Show run for Switch2 (S2):
Switch#sh run
Current configuration : 1142 bytes
version 15.0
hostname Switch
interface Vlan1
 ip address 192.168.20.66 255.255.255.224
 shutdown
ip default-gateway 192.168.20.65
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
I have also attached the Packet Tracer file. Ignore the little network that is at the bottom of the topology that isn't connected to anything, that was just me trying to troubleshoot on a smaller scale. Please let me know if I need to show anymore show commands. Thank you so much, I appreciate any help!
You need to configure a static route for every network that's not connected to that router.
I would recommend just implementing a routing protocol to make your life easier unless the assignment is specific to you creating static routes only.
router eigrp 1
network 0.0.0.0 255.255.255.255
Hope this helps.
-David
router eigrp 1
Hope this helps.
-David
Hey David,
That worked, thank you so much! If you don't mind me asking, how exactly does this routing protocol work? Like what does "router eigrp 1" do?
Thank you again!
Routing protocols exchange routes. Simple as that. Now the mechanism in which they exchange routes is a bit more involved and complicated but essentially it does what static routes do on a more dynamic scale. For instance:
Your static route has a statement that says this network is out this interface (or next hop IP). A routing protocol will send information about it known routes to its neighbors and they exchange routing information. I just picked EIGRP but you could have used OSPF or RIP for Packet Tracer. Everyone has their likes/dislikes of the routing protocols, and each have their pros/cons in certain network designs.
router eigrp 1 <- turns on the EIGRP process and assigns it to Autonomous System 1 - this can be any # but they must match between router peers to form a neighbor adjacency.
network 0.0.0.0 255.255.255.255 <- this command enables EIGRP packets to be sent out interfaces in this range and it also advertises its interface networks to its neighbors.
Specifically 0.0.0.0 255.255.255.255 means all networks/interfaces.
There are way better resources on routing protocols than what I can explain here. You can try some CCNA level YouTube videos to help you better understand routing protocols. These are very involved protocols that require several chapters (and even whole books) written about them
-David
