PC can't access the internet through the Router--> Default Route isn't working
Vasconcelos
Good night, everyone, I'm learning network and I'm facing the problem bellow for hours. I'll rate the users who help
Note: I'm using real equipment, used GNS3 for the Image. The Ports are specified on the image
PC
 IP--> 172.30.100.50
 Mask--> 255.255.255.0
 D.Gateway--> 172.30.100.1
Router
 Fa0/0
     IP--> 172.30.100.1
 Fa0/1
     IP--> 192.168.0.11 (DHCP)
Modem (ISP)
 IP-->192.168.0.1
I've issued the command "ip route 0.0.0.0 0.0.0.0 192.168.0.1"
From the PC, I can ping the Interface Fa0/0 and Fa0/1 of the Router, but I can't ping the Modem (ISP)
From the Router, I can ping the PC, both Interfaces of the Router and the Modem (ISP)
Since I can ping the Modem from the Router and I can ping the Interface Fa0/1 of the Router from the PC, the problem must be on the routing process
Router's Running-Config
Current configuration : 920 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address 172.30.100.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip forward-protocol nd
ip route 192.168.0.0 255.255.255.0 192.168.0.1
ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
3 Accepted Solutions
Larry Sullivan
Level 3
Level 3
What happens if you NAT/PAT the PC IP to the Router's F0/1 interface IP?
I think Larry is right. Your router can ping the modem, because it's on the same network subnet as the modem. The PC cannot ping the modem because you are attempting to route 172.30.100.x through the router, but the modem won't know about that subnet, so will not route the return traffic back to the router....it would use it's default route which points to the internet.
If you NAT the local network (172.30.100.x) behind the router using the Fa0/1 interface the router will know how to return that traffic.
for the sake of clarity, here is what the config should look like (important parts are in bold):
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 dhcp
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 172.30.100.0 0.0.0.255
ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
7 Replies 7
Larry Sullivan
Level 3
Level 3
By using the command traceroute on the Router, I can see that the Modem provided by my ISP is using a Private IP (192.168.0.1) and so is the next hop after it (10.x.x.x). Only after that the IPs begin to be Global with the IP 189.x.x.x
So, Doing NAT or PAT in the FA0/1 wouldn't work
Globally routable address has nothing to do with it.  You can NAT private to private.  RJI covered exactly what I think the issue is.
Skywalker
True, i also side with Larry. Also, before testing from your PC, you should be able to ping the outside networks from the router while sourcing the ping from the LAN gateway.
Like;
ping 8.8.8.8 source 172.30.100.1
__
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
Vasconcelos
Since I can't reply to everyone in just one message, I'll use this
Thanks, everyone. I've rated every post.
