PC's on network cannot access internet through WAN
manuelcruz3288
Hi Guys,
I appreciate any help on this. I have a Cisco 1941 Router that i just factory defaulted. I configured the GB Inter 0/0 to be the LAN 192.168.4.250 255.255.255.0 and the GB Inter 0/1 (Public IP) 255.255.255.248. I can ping the internet and internal network pc's from the WAN interface (GB Inter 0/1). as for the GB Inter 0/0 i can ping the wan interface but i cannot ping an external source by name or ip address. I do have DNS configured on the router and any pc being used on the internal network. DHCP is disabled because we have a DHCP server. My show running-config is below. Any help is appreciated very much. Let me know if any other info is needed to diagnose the issue. Also no access lists are applied either.
Current configuration : 5397 bytes
! Last configuration change at 15:44:02 UTC Wed Feb 12 2014 by michael
! NVRAM config last updated at 15:40:26 UTC Wed Feb 12 2014
version 15.1
service password-encryption
hostname 107TestRouter
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name libertysport.com
ip name-server 75.75.75.75
ip name-server 75.75.76.76
crypto pki trustpoint TP-self-signed-3136076189
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3136076189
revocation-check none
rsakeypair TP-self-signed-3136076189
crypto pki certificate chain TP-self-signed-3136076189
certificate self-signed 01
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
2 Accepted Solutions
Your NAT config would be -
int gi0/0
ip nat inside
int gi0/1
ip nat outside
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
ip nat inside source list 101 interface gi0/1 overload
Jon
If i understand your question correctly the acl used in the NAT statement is only used to tell the router which IPs to NAT. It is not applied to any interface as you would with an acl that was controlling traffic through that interface.
There are a lot of different uses for acls and for a lot of things the acl is not directly applied to the router's interfaces.
Jon
9 Replies 9
Jon Marshall
You haven't posted the full configuration but have do you have NAT setup for the internal clients ?
Jon
Hi Jon, thank you for your response. No I haven't setup NATing yet. Shall I config it with 0/1 outside and 0/0 inside? I'll post  full config ASAP.
int gi0/0
ip nat inside
int gi0/1
ip nat outside
Jon
Jon, you fixed it! Im able to get out now. I can't believe it was that easy, must searches ive found lead me to the overload statement but wasnt sure enough to try it myself.
No problem, glad to have helped.
Jon
When i do a show ip interface gbint0/1 how come i dont see that the ip nat inside source list 101 interface gi0/1 overload is shown under outgoing or inbound access list?
Jon
manuelcruz3288
Understood and thank you. Is there a command to verify or view that this statement is in effect? kinda like viewing the acl's tied to an interface?
You can do -
1) a simple "sh run to see if it is configured
2)  "sh access-list 101" to see if there are hits on the acl
3) "sh ip nat translations" to see exactly what NAT translations are happening on your router.
Jon
