PDU fail to send to remote network
TP062362
Greetings,
So I've a topology which includes several LAN topologies. The current setup have all static routing and configured Ip address in all devices. The problem that I'm encountering is that the end-device circled in black couldn't send PDU to the end-device in rectangle vice versa. I've done tracert for both of the end-device to ping each other and the results stops at their respective router e.g. Offsite Server 1 stops at Offsite Router's IP address and so on...
but the problem is that the PDU only works for PNG LAN which contains 20 Host but for other LAN's it doesn't
I've pretty sure I've missed anything as the PNG LAN succeeded. Please help me out.
Thank you!
0 Replies 0
