PDU or routing issues
Ayad
When i try to ping my router i get the U caracter :
Sending 5, 100-byte ICMP Echos to 80.125.46.36, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
but i can access via telnet to this device.
Does someone know or explain this issue ? is this will cause problems to incoming /out trafic of this remote router ?
Thanks for your reply.
regards,
Giuseppe Larosa
Hello Abzaz,
with telnet you try to open  a TCP (protocol 6) session to port 23 (telnet)
with ICMP you send out packet with protocol 1 code echo request
I would say there is an extended ACL allowing telnet and denying ICMP packets
Hope to help
Giuseppe
