wan failover with vpn
tjd2112pcca
Hello all,
I have a question about a merged configuration which I attempted to get working recently with no luck. Our organization has a 1841 router which is it's primary router to ISP#1. This was a T1 connection which was being overworked by all of our Internet traffic. We bought a 1941 with an Ethernet card giving it 3 Ethernet interfaces. This 1941 router is connected to ISP#2 (Comcast). The 1841 has WebVPN config and a L2L VPN to another office. We want to retire the 1841 and just use the 1941 connected to both networks. When I tried to paste in the parts of the 1841 config into the 1941 all was ok from the Internet access perspective, but the VPNs do not function anymore. I also used a zone based firewall config on the 1941. Which traffic do I need to allow in for the L2L and SSL VPNs to work? I also set up a floating static route for the router to failover to ISP#1 (Comcast link is the primary) if the Comcast link goes down. The VPN traffic was setup to go out ISP#1, how do I make the VPN traffic go out to ISP#1 but keep the default route set to Comcast(ISP#2)? Sorry for the long post.
richardboldy
If you post your configs (minus any passwords) you'll probably get someone to help you.
Here is the config of the 1941:
! Last configuration change at 20:51:24 UTC Fri Aug 13 2010 by user
version 15.0
hostname cisco
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authentication login external-vpn-users local group radius
aaa authentication login webvpn local
aaa authorization exec default local
aaa authorization network external-vpn-groups local
aaa authorization network external-vpn-users group radius local
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip domain name domain.com
ip name-server 68.87.64.150
crypto pki trustpoint TP-self-signed-3735527223
enrollment selfsigned
ip-address 199.72.119.2
subject-name cn=IOS-Self-Signed-Certificate-3735527223
revocation-check none
rsakeypair TP-self-signed-3735527223
crypto pki certificate chain TP-self-signed-3735527223
certificate self-signed 01
  quit
license udi pid CISCO1941/K9 sn serial #
username user privilege 15 secret 5 passwd
redundancy
class-map type inspect match-any CMAP-1
match protocol tcp
match protocol icmp
match protocol udp
class-map type inspect match-all pptp-passthru
match access-group name PPTP-PASS-THROUGH
policy-map type inspect PMAP-1
class type inspect CMAP-1
  inspect
class type inspect pptp-passthru
  pass
class class-default
  drop
policy-map type inspect PMAP-2
  pass
class class-default
  drop
zone security inside
zone security outside
zone-pair security inside-to-outside source inside destination outside
service-policy type inspect PMAP-1
zone-pair security outside-to-inside source outside destination inside
service-policy type inspect PMAP-2
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key key address 64.32.253.138 no-xauth
crypto isakmp client configuration group vpn-group-1
key key
dns 10.1.9.254
wins 10.1.9.254
domain fesnakllp.com
pool vpn_users1
acl 151
netmask 255.255.255.0
crypto isakmp profile VPNclient
   match identity group vpn-group-1
crypto ipsec transform-set sonicwall esp-3des esp-md5-hmac
crypto ipsec transform-set client-tsset esp-3des esp-sha-hmac
crypto dynamic-map client-map 1
set transform-set client-tsset
set isakmp-profile VPNclient
reverse-route
crypto map external-crypto client authentication list external-vpn-users
crypto map external-crypto isakmp authorization list external-vpn-groups
crypto map external-crypto client configuration address respond
crypto map external-crypto 10 ipsec-isakmp
description Tunnel to Sonicwall / 64.32.253.138
set peer 64.32.253.138
set security-association lifetime seconds 86400
set transform-set sonicwall
match address 150
crypto map external-crypto 65535 ipsec-isakmp dynamic client-map
interface Loopback2
description This is needed for WebVPN address pool
ip address 10.3.1.126 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0
description Internal LAN
ip address 10.1.9.251 255.255.255.0
ip mask-reply
ip nat inside
zone-member security inside
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
description Internet via Comcast
ip address 75.151.154.178 255.255.255.248
ip nat outside
zone-member security outside
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/0/0
description Internet via Paetec
ip address 199.72.119.2 255.255.255.248
ip nat outside
shutdown
duplex auto
speed auto
no cdp enable
no mop enabled
ip local pool vpn_users1 10.2.1.1 10.2.1.100
ip local pool webvpn_users 10.3.1.1 10.3.1.100
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 105 interface GigabitEthernet0/1 overload
ip nat inside source route-map nonat-vpn interface FastEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 75.151.154.182
ip route 0.0.0.0 0.0.0.0 199.72.119.1 250
ip route 10.2.1.0 255.255.255.0 199.72.119.1 permanent
ip route 10.3.1.0 255.255.255.0 199.72.119.1 permanent
ip access-list extended PPTP-PASS-THROUGH
permit gre any any
access-list 100 remark NAT policy for this router
access-list 100 remark Deny NAT for packets via VPN
access-list 100 deny   ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 100 remark Deny NAT for packets to VPN clients (ippool)
access-list 100 deny   ip any host 10.2.1.1
access-list 100 deny   ip any host 10.2.1.2
access-list 100 deny   ip any host 10.2.1.3
access-list 100 deny   ip any host 10.2.1.4
access-list 100 deny   ip any host 10.2.1.5
access-list 100 deny   ip any host 10.2.1.6
access-list 100 deny   ip any host 10.2.1.7
access-list 100 deny   ip any host 10.2.1.8
access-list 100 deny   ip any host 10.2.1.9
access-list 100 deny   ip any host 10.2.1.10
access-list 100 deny   ip any host 10.2.1.11
access-list 100 deny   ip any host 10.2.1.12
access-list 100 deny   ip any host 10.2.1.13
access-list 100 deny   ip any host 10.2.1.14
access-list 100 deny   ip any host 10.2.1.15
access-list 100 deny   ip any host 10.2.1.16
access-list 100 deny   ip any host 10.2.1.17
access-list 100 deny   ip any host 10.2.1.18
access-list 100 deny   ip any host 10.2.1.19
access-list 100 deny   ip any host 10.2.1.20
access-list 100 deny   ip any host 10.2.1.21
access-list 100 deny   ip any host 10.2.1.22
access-list 100 deny   ip any host 10.2.1.23
access-list 100 deny   ip any host 10.2.1.24
access-list 100 deny   ip any host 10.2.1.25
access-list 100 deny   ip any host 10.2.1.26
access-list 100 deny   ip any host 10.2.1.27
access-list 100 deny   ip any host 10.2.1.28
access-list 100 deny   ip any host 10.2.1.29
access-list 100 deny   ip any host 10.2.1.30
access-list 100 deny   ip any host 10.2.1.31
access-list 100 deny   ip any host 10.2.1.32
access-list 100 deny   ip any host 10.2.1.33
access-list 100 deny   ip any host 10.2.1.34
access-list 100 deny   ip any host 10.2.1.35
access-list 100 deny   ip any host 10.2.1.36
access-list 100 deny   ip any host 10.2.1.37
access-list 100 deny   ip any host 10.2.1.38
access-list 100 deny   ip any host 10.2.1.39
access-list 100 deny   ip any host 10.2.1.40
access-list 100 deny   ip any host 10.2.1.41
access-list 100 deny   ip any host 10.2.1.42
access-list 100 deny   ip any host 10.2.1.43
access-list 100 deny   ip any host 10.2.1.44
access-list 100 deny   ip any host 10.2.1.45
access-list 100 deny   ip any host 10.2.1.46
access-list 100 deny   ip any host 10.2.1.47
access-list 100 deny   ip any host 10.2.1.48
access-list 100 deny   ip any host 10.2.1.49
access-list 100 deny   ip any host 10.2.1.50
access-list 100 deny   ip any host 10.2.1.51
access-list 100 deny   ip any host 10.2.1.52
access-list 100 deny   ip any host 10.2.1.53
access-list 100 deny   ip any host 10.2.1.54
access-list 100 deny   ip any host 10.2.1.55
access-list 100 deny   ip any host 10.2.1.56
access-list 100 deny   ip any host 10.2.1.57
access-list 100 deny   ip any host 10.2.1.58
access-list 100 deny   ip any host 10.2.1.59
access-list 100 deny   ip any host 10.2.1.60
access-list 100 deny   ip any host 10.2.1.61
access-list 100 deny   ip any host 10.2.1.62
access-list 100 deny   ip any host 10.2.1.63
access-list 100 deny   ip any host 10.2.1.64
access-list 100 deny   ip any host 10.2.1.65
access-list 100 deny   ip any host 10.2.1.66
access-list 100 deny   ip any host 10.2.1.67
access-list 100 deny   ip any host 10.2.1.68
access-list 100 deny   ip any host 10.2.1.69
access-list 100 deny   ip any host 10.2.1.70
access-list 100 deny   ip any host 10.2.1.71
access-list 100 deny   ip any host 10.2.1.72
access-list 100 deny   ip any host 10.2.1.73
access-list 100 deny   ip any host 10.2.1.74
access-list 100 deny   ip any host 10.2.1.75
access-list 100 deny   ip any host 10.2.1.76
access-list 100 deny   ip any host 10.2.1.77
access-list 100 deny   ip any host 10.2.1.78
access-list 100 deny   ip any host 10.2.1.79
access-list 100 deny   ip any host 10.2.1.80
access-list 100 deny   ip any host 10.2.1.81
access-list 100 deny   ip any host 10.2.1.82
access-list 100 deny   ip any host 10.2.1.83
access-list 100 deny   ip any host 10.2.1.84
access-list 100 deny   ip any host 10.2.1.85
access-list 100 deny   ip any host 10.2.1.86
access-list 100 deny   ip any host 10.2.1.87
access-list 100 deny   ip any host 10.2.1.88
access-list 100 deny   ip any host 10.2.1.89
access-list 100 deny   ip any host 10.2.1.90
access-list 100 deny   ip any host 10.2.1.91
access-list 100 deny   ip any host 10.2.1.92
access-list 100 deny   ip any host 10.2.1.93
access-list 100 deny   ip any host 10.2.1.94
access-list 100 deny   ip any host 10.2.1.95
access-list 100 deny   ip any host 10.2.1.96
access-list 100 deny   ip any host 10.2.1.97
access-list 100 deny   ip any host 10.2.1.98
access-list 100 deny   ip any host 10.2.1.99
access-list 100 deny   ip any host 10.2.1.100
access-list 100 deny   ip any host 10.3.1.1
access-list 100 deny   ip any host 10.3.1.2
access-list 100 deny   ip any host 10.3.1.3
access-list 100 deny   ip any host 10.3.1.4
access-list 100 deny   ip any host 10.3.1.5
access-list 100 deny   ip any host 10.3.1.6
access-list 100 deny   ip any host 10.3.1.7
access-list 100 deny   ip any host 10.3.1.8
access-list 100 deny   ip any host 10.3.1.9
access-list 100 deny   ip any host 10.3.1.10
access-list 100 deny   ip any host 10.3.1.11
access-list 100 deny   ip any host 10.3.1.12
access-list 100 deny   ip any host 10.3.1.13
access-list 100 deny   ip any host 10.3.1.14
access-list 100 deny   ip any host 10.3.1.15
access-list 100 deny   ip any host 10.3.1.16
access-list 100 deny   ip any host 10.3.1.17
access-list 100 deny   ip any host 10.3.1.18
access-list 100 deny   ip any host 10.3.1.19
access-list 100 deny   ip any host 10.3.1.20
access-list 100 deny   ip any host 10.3.1.21
access-list 100 deny   ip any host 10.3.1.22
access-list 100 deny   ip any host 10.3.1.23
access-list 100 deny   ip any host 10.3.1.24
access-list 100 deny   ip any host 10.3.1.25
access-list 100 deny   ip any host 10.3.1.26
access-list 100 deny   ip any host 10.3.1.27
access-list 100 deny   ip any host 10.3.1.28
access-list 100 deny   ip any host 10.3.1.29
access-list 100 deny   ip any host 10.3.1.30
access-list 100 deny   ip any host 10.3.1.31
access-list 100 deny   ip any host 10.3.1.32
access-list 100 deny   ip any host 10.3.1.33
access-list 100 deny   ip any host 10.3.1.34
access-list 100 deny   ip any host 10.3.1.35
access-list 100 deny   ip any host 10.3.1.36
access-list 100 deny   ip any host 10.3.1.37
access-list 100 deny   ip any host 10.3.1.38
access-list 100 deny   ip any host 10.3.1.39
access-list 100 deny   ip any host 10.3.1.40
access-list 100 deny   ip any host 10.3.1.41
access-list 100 deny   ip any host 10.3.1.42
access-list 100 deny   ip any host 10.3.1.43
access-list 100 deny   ip any host 10.3.1.44
access-list 100 deny   ip any host 10.3.1.45
access-list 100 deny   ip any host 10.3.1.46
access-list 100 deny   ip any host 10.3.1.47
access-list 100 deny   ip any host 10.3.1.48
access-list 100 deny   ip any host 10.3.1.49
access-list 100 deny   ip any host 10.3.1.50
access-list 100 deny   ip any host 10.3.1.51
access-list 100 deny   ip any host 10.3.1.52
access-list 100 deny   ip any host 10.3.1.53
access-list 100 deny   ip any host 10.3.1.54
access-list 100 deny   ip any host 10.3.1.55
access-list 100 deny   ip any host 10.3.1.56
access-list 100 deny   ip any host 10.3.1.57
access-list 100 deny   ip any host 10.3.1.58
access-list 100 deny   ip any host 10.3.1.59
access-list 100 deny   ip any host 10.3.1.60
access-list 100 deny   ip any host 10.3.1.61
access-list 100 deny   ip any host 10.3.1.62
access-list 100 deny   ip any host 10.3.1.63
access-list 100 deny   ip any host 10.3.1.64
access-list 100 deny   ip any host 10.3.1.65
access-list 100 deny   ip any host 10.3.1.66
access-list 100 deny   ip any host 10.3.1.67
access-list 100 deny   ip any host 10.3.1.68
access-list 100 deny   ip any host 10.3.1.69
access-list 100 deny   ip any host 10.3.1.70
access-list 100 deny   ip any host 10.3.1.71
access-list 100 deny   ip any host 10.3.1.72
access-list 100 deny   ip any host 10.3.1.73
access-list 100 deny   ip any host 10.3.1.74
access-list 100 deny   ip any host 10.3.1.75
access-list 100 deny   ip any host 10.3.1.76
access-list 100 deny   ip any host 10.3.1.77
access-list 100 deny   ip any host 10.3.1.78
access-list 100 deny   ip any host 10.3.1.79
access-list 100 deny   ip any host 10.3.1.80
access-list 100 deny   ip any host 10.3.1.81
access-list 100 deny   ip any host 10.3.1.82
access-list 100 deny   ip any host 10.3.1.83
access-list 100 deny   ip any host 10.3.1.84
access-list 100 deny   ip any host 10.3.1.85
access-list 100 deny   ip any host 10.3.1.86
access-list 100 deny   ip any host 10.3.1.87
access-list 100 deny   ip any host 10.3.1.88
access-list 100 deny   ip any host 10.3.1.89
access-list 100 deny   ip any host 10.3.1.90
access-list 100 deny   ip any host 10.3.1.91
access-list 100 deny   ip any host 10.3.1.92
access-list 100 deny   ip any host 10.3.1.93
access-list 100 deny   ip any host 10.3.1.94
access-list 100 deny   ip any host 10.3.1.95
access-list 100 deny   ip any host 10.3.1.96
access-list 100 deny   ip any host 10.3.1.97
access-list 100 deny   ip any host 10.3.1.98
access-list 100 deny   ip any host 10.3.1.99
access-list 100 deny   ip any host 10.3.1.100
access-list 100 remark NAT everything else
access-list 100 permit ip 10.1.9.0 0.0.0.255 any
access-list 105 remark CCP_ACL Category=2
access-list 105 permit ip 10.0.0.0 0.255.255.255 any
access-list 110 deny   ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 120 permit ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 150 remark Permit traffic between here and remote LAN via IPSEC
access-list 150 permit ip 10.1.9.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 151 remark ACL for VPN Client Split Tunneling
access-list 151 permit ip 10.1.9.0 0.0.0.255 any
no cdp run
route-map nonat-vpn permit 1
match ip address 100
radius-server host 10.1.9.254 auth-port 1645 acct-port 1646 key 12345
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
scheduler allocate 20000 1000
webvpn gateway WebVPNGateway
ip address 199.72.119.2 port 443
ssl encryption 3des-sha1
ssl trustpoint TP-self-signed-3735527223
inservice
webvpn context Default_context
ssl authenticate verify all
nbns-list "Windows_Servers"
   nbns-server 10.1.9.254 master
port-forward "WebVPN_Ports"
   local-port 3001 remote-server "10.1.9.254" remote-port 2029 description "MSSQLPROFXENGAGEMENT"
   local-port 3002 remote-server "10.1.9.254" remote-port 6735 description "PFXEngDesktopService"
   local-port 3003 remote-server "10.1.9.254" remote-port 6736 description "PFXSYNPFTService"
   local-port 3004 remote-server "10.1.9.254" remote-port 1434 description "SQL Listening Service"
policy group WebVPN_Policy
   functions file-access
   functions file-browse
   functions file-entry
   functions svc-required
   svc address-pool "webvpn_users"
   svc default-domain "fesnakllp.com"
   svc keep-client-installed
   svc dpd-interval gateway 30
   svc rekey method new-tunnel
   svc split include 10.1.9.0 255.255.255.0
   svc dns-server primary 10.1.9.254
   svc wins-server primary 10.1.9.254
default-group-policy WebVPN_Policy
aaa authentication list external-vpn-users
inservice
end
I think it's that there are no ports open for the incoming VPN traffic. I can't bring this down alot to test. Can anyone tell me if i'm on the right track?
Thanks.
