Peer networking on ASR 1001-X (Warning: use /31 mask on non point-to-point interface cautiously)
tahscolony
I have a question I need an answer on, so hopefully someone has done this in production.  We have a trunk coming from a cloud provider, they assign a /31 block, 255.255.255.254 IP for the links.  I am labbing this up on 2811 routers and discovered when I use a /31 I cannot ping across the link.  Since the actual connection will be layer 2 back to our router, through a series of switches, and will terminate on a subinterface, I have the lab setup as it will be in production.  If I use a /30, of course it works fine.
What I need to know is if on the ASR 1001-X if a /31 address will work in this scenario, as in platform specific issues, or older IOS issues.  I do know that earlier versions in the same train wont even allow me to do a /31 subnet.  I basically can't imagine it not working on the newer platform since cloud providers use a trunk to connect to the customer and route various networks over it using /31 subnets.
just verified, this works on IOS XE as well. I have tested it on XE 3.16 release - 15.5(3)S
--Vinit
Vinit Jain
i tried it on VIRL and it works fine. I am using 15.5 release. What is the IP address that you are using on both sides?
--Vinit
Will check it on IOS XE as well and see if there is any issue noticed
--Vinit
--Vinit
Perfect, that is what I needed to know. I am running older 12.4 code on a pair of 2811, and had a feeling it was just due to the IOS version and/or platform.  For an IP I use 66.77.88.1 and just realized WHY it didn't work.  DOH, OK back to subnetting school for me.  I will try with the CORRECT IP addresses of 0 and 1.
EDIT. Yeah, thats what it was. I put the correct IP's on the interface so they fall into the proper subnet and bingo, got it working, along with VRF and BGP import/export routing. Now just need to get BGP into OSPF and vise versa for internal routing and then my POC will be done.
