Bookmark
Subscribe
787
Perimeter firewall- Risks running OSPF
mvsheik123
Level 7
Level 7
Hello all,
We have ASA5510 at our perimeter and is running OSPF on inside interface.
1.  Iam planning to add DMZ and adding th DMZ subnet also to OSPF process for advertising the DMZ dynanmically into network.
Any security risks?
2. Near future we will add BGP and a perimeter router (Internet router) with Dual ISPs and to advertise the default route from Internet router to OSPF domain- Planning to enable OSPF between Internet router and ASA outside interface and redistribute BGP into OSPF. Would like to know the security risks in doing so. Please suggest. Sample configs below for step1 & 2.
Current:
ASA:
inter Eth0/1
nameif inside
ip address 10.10.10.1 255.255.255.0
inter Eth0/0
nameif outside
ip address 67.27.36.194 255.255.255.248
router ospf 100
network 10.10.10.1 255.255.255.255
route outside 0.0.0.0 0.0.0.0 (nexthop IP)
ASA after DMZ:
inter Eth0/2
nameif DMZ
ip address 192.168.40.1 255.255.255.0
router ospf 100
network 192.168.40.1 255.255.255.255
ASA with internet router/BGP:
inter Eth0/0
nameif outside
ip address 7.7.7.10 255.255.255.0
router ospf 100
network 7.7.7.10 255.255.255.255
Remove the default route
Internet router:
Inter gig0/1
des: to ISP
ip addess 20.20.20.1 255.255.255.252
Inter gig0/1
des: to ASA
ip addess 7.7.7.5 255.255.255.0
router ospf 100
router id 7.7.7.5
network 7.7.7.5 255.255.255.255
redistribute BGP <default route>
router bgp 64345
neighbor < > remote-as <>
network 7.7.7.0 mask 255.255.255.0
Thanks in Advance
MS
mvsheik123
Level 7
Level 7
Hello everybody,
I was able to do some tests and with reference to the risks.Adding DMZ interface dynamic routing process is fine ( as it has already been enabled for inside interface), but not for the outside. The perimeter router learning all internal network routes:-). This is much anticipated result, but just wanted to check it out. Thanks all for reading this.
MS
