PFR automatic learning list Inactive ?
Junior Mateus
Hello Everybody ,
i have one MC/BR and one BR :
Border           Status   UP/DOWN             AuthFail  Version
3.3.3.3          ACTIVE   UP       00:11:12          0  3.0
10.30.21.1       ACTIVE   UP       00:11:10          0  3.0
MY  Goal is the learn some classify traffic automatically and then apply policy for this traffic-class
Configuration ACL
ip access-list extended Defined_PFR_Appl
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq smtp
ip access-list extended icmp
permit icmp any any
Configuration Automatic learning list
RT-EDGE-INTERNET2#sh pfr master
OER state: ENABLED and ACTIVE
  Conn Status: SUCCESS, PORT: 3949
  Version: 3.0
Number of Border routers: 2
  Number of Exits: 4
  Number of monitored prefixes: 412 (max 5000)
  Max prefixes: total 5000 learn 2500
  Prefix count: total 412, learn 412, cfg 0
  PBR Requirements met
  Nbar Status: Inactive
3.3.3.3          ACTIVE   UP       00:16:05          0  3.0
10.30.21.1       ACTIVE   UP       00:16:03          0  3.0
Global Settings:
  max-range-utilization percent 20 recv 0
  mode route metric bgp local-pref 5000
  mode route metric static tag 5000
  trace probe delay 1000
  logging
  exit holddown time 60 secs, time remaining 0
Default Policy Settings:
  backoff 300 3000 300
  delay relative 50
  holddown 300
  periodic 0
  probe frequency 56
  number of jitter probe packets 100
  mode route observe
  mode monitor both
  mode select-exit good
  loss relative 10
  jitter threshold 20
  mos threshold 3.60 percent 30
  unreachable relative 50
  resolve delay priority 11 variance 20
  resolve range priority 12 variance 0
  resolve utilization priority 13 variance 20
Learn Settings:
  current state : STARTED
  time remaining in current state : 99 seconds
  throughput
  no delay
  no inside bgp
  monitor-period 1
  periodic-interval 0
  aggregation-type prefix-length 24
  prefixes 100 appls 100
  expire after time 720
  Learn-List seq 5 refname PBR_APPL
    Configuration:
     Traffic-Class Access-list: Defined_PFR_Appl
     Aggregation-type: prefix-length 24
     Learn type: delay
     Session count: 50 Max count: 90
     Status: INACTIVE
    Stats:
     Traffic-Class Count: 0
  Learn-List seq 6 refname icmp
    Configuration:
     Traffic-Class Access-list: icmp
     Learn type: throughput
     Session count: 1000 Max count: 1000
     Status: INACTIVE
    Stats:
Configuration Enabling PFR-MAP for this leanring list
pfr-map Test_MAP 10
match pfr learn list PBR_APPL
pfr-map Test_MAP 11
match pfr learn list icmp
So i really don ´t understand, why i can´t match any access-list on the learn list ?
here is the output of ip cache flow
RT-EDGE-INTERNET2#sh ip cache flow
IP packet size distribution (4005785 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .005 .531 .059 .066 .027 .022 .062 .019 .007 .051 .006 .003 .001 .004 .001
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
   .002 .005 .000 .009 .110 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 278544 bytes
  268 active, 3828 inactive, 957020 added
  21121500 ager polls, 0 flow alloc failures
  Active flows timeout in 1 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 66824 bytes
  438 active, 1610 inactive, 1123853 added, 957020 added to flow
  0 alloc failures, 0 force free
  2 chunks, 6 chunks added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
TCP-Telnet         337      0.0        61    41      0.1      21.1      10.4
TCP-FTP              1      0.0         1    40      0.0       0.0      15.9
TCP-WWW           5239      0.0         6   759      0.1       5.8      17.3
TCP-SMTP             4      0.0         1    49      0.0       0.0      15.4
TCP-X               91      0.0         1    40      0.0       0.2      19.4
TCP-BGP            722      0.0         1    49      0.0       2.9      15.4
TCP-other       356939      1.9         4   392      8.3       3.1      14.6
UDP-DNS         109259      0.5         2    66      1.2       5.3      15.3
UDP-NTP           1323      0.0         2    78      0.0       4.3      15.5
UDP-TFTP            91      0.0         1    57      0.0       0.0      15.5
UDP-other       362001      1.9         1   185      3.6       2.4      15.4
ICMP            102757      0.5         4   151      2.2       2.6      15.4
GRE              15822      0.0        60   163      5.1      26.6      15.3
IP-other           690      0.0       120   146      0.4     308.1       7.7
Total:          955276      5.1         4   253     21.5       3.7      15.1
And here is the output of learning list
RT-EDGE-INTERNET2#sh pfr master learn li
RT-EDGE-INTERNET2#sh pfr master learn list
   Configuration:
    Learn type: delay
    Status: INACTIVE
   Stats:
   Configuration:
    Status: INACTIVE
   Stats:
sathvik k v
Level 3
Level 3
Hi Junior,
Have you applied the pfr-map under pfr master using policy-rules Test_MAP ?
Sathvik
sathvik k v
Level 3
Level 3
Hi Junior,
Sathvik
yes you was right  SathVik, now i have apply the pfr-map to the Gobal Policy, it working fine thanks for help
