PfR Traffic Class as defined by a learn list
mcarlton62
I have a Cisco Live PfR Lab Book from 2009 that describes the use of an ACL in a PFR Map to define the Networks in the MTC. The format in the lab is :
ip access-list ext matchEF
permit ip any 100.1.1.0 0.0.0.255 dscp ef   (these match the destination prefix being managed or monitored)
permit ip any 100.1.2.0 0.0.0.255 dscp ef
In my lab, this does not work
ip access-list ext Voice
permit ip any 10.223.9.0 0.0.0.255 dscp ef   (phones vlan in my lab network)
But this does work
permit ip any any dscp ef
(but it also pick up and manages the Probes coming from the remote end and forces both probes over the same WAN connection)
ATRLAB-CC1WR1#sh pfr master tr
OER Prefix Statistics:
Pas - Passive, Act - Active, S - Short term, L - Long term, Dly - Delay (ms),
P - Percentage below threshold, Jit - Jitter (ms),
MOS - Mean Opinion Score
Los - Packet Loss (packets-per-million), Un - Unreachable (flows-per-million),
E - Egress, I - Ingress, Bw - Bandwidth (kbps), N - Not applicable
U - unknown, * - uncontrolled, + - control more specific, @ - active probe all
# - Prefix monitor mode is Special, & - Blackholed Prefix
% - Force Next-Hop, ^ - Prefix is denied
DstPrefix           Appl_ID Dscp Prot     SrcPort     DstPort SrcPrefix
           Flags             State     Time            CurrBR  CurrI/F Protocol
         PasSDly  PasLDly   PasSUn   PasLUn  PasSLos  PasLLos      EBw      IBw
         ActSDly  ActLDly   ActSUn   ActLUn  ActSJit  ActPMOS  ActSLos  ActLLos
10.223.9.0/24             N   ef  256           N           N 0.0.0.0/0
                          INPOLICY      @54       10.223.31.2 Fa1/0           PBR
               U        U        0        0        0        0        0       65
              12       12        0        0        1        0     5333        0
10.223.254.0/30           N   ef  256           N           N 0.0.0.0/0                   (this is a probe from the remote WAN router)
                          DEFAULT*       @3       10.223.31.2 U               U
10.223.255.0/30           N   ef  256           N           N 0.0.0.0/0                   (this is a probe from the remote WAN router)
ATRLAB-CC1WR1#
any thoughts on why the more specific list does not work?
Hi There,
if you have a couple of hours you will find the exact answer here:
http://www.ine.com/all-access-pass/training/playlist/ccie-rs-pfr-vseminar/-pfr--vseminar-22200011.html
Alessio
Alessio
     I have watched these video's, actually watched them before I started developing a PFR solution for my network. This is not the solution to my problem. I am running 15.1 code in one scenario and 15.2 in another. The ACL no longer has to match the specific route. In my case, from above, I have learned 10.223.9.0. That route does not exist in the routing table. The routing table has 10.223.0.0/20 and the ACL is using IP any any. So in my case pfr works when the acl entry does not match the network and does not work when I do match the network. BTW, PFR conditions are met in both configurations.
Thanks anyway!
Mark
