PfRv3 load balancing
Hi everyone,
I would be grateful if you could help me with the following doubt. When using PfRv3 load-balancing, only applies to the default class or can other  classes of higher priority be load-balanced too? I'm reading documentation about PfRv3 and all the examples show a more priority link for higher classes of services and only the default one is load-balanced. I would appreciate if you could redirect me to any example of this config.
Thanks in advance
Octavio
Kyle McKay
Hey Octavio,
Load balancing does indeed only apply to the default class and no other classes. I am not able to find any resources which can confirm this however I assure you based on experience this is true.
