phone registering Cisco 2900 router serial port
hi Sir,
        I'm using both the ports ( that ethernet and serial ) backside the router for communication between two location. Serial port is through satellite link and the Ethernet  line through leased line.Also Im using IPSLA commands that when the leased line is down the link is alive through serial.But as the serial has very small bandwidth ,is it possible that when the leased line is down and traffic s through serial port , only one or two phones gets registerd instead of all .As I have only 64kbps bandwidth through serial or max 192Kbps. On 64 Kbps one ip (cisco 3905) phone easily gets registerd.
Pawan Raut
Level 4
Level 4
apply acl on serial interface and allow those phone IP  which you want to be register.
Kindly rate or useful post
