Cisco 1800 in lan (IOS 15) drops packets when pinging public IPS
seankeltsch
I recently got a MikroTik Routerboard ( https://routerboard.com/RB2011UiAS-2HnD-IN ) and am trying to establish public internet connectivity from my Cisco Lab, which is three routers and three switches, but regardless of what I do the I am routinely dropping 3-5 packets.
My setup is Cable Modem ------  > Routerboard ( my standard residence network is connected here) (192.168.8.1)  LAB ----> Cisco 1800 (192.168.8.2 Fa 0/1)  ----> 2 more Cisco 1800s ------- > Catalyst 3560 ---> 2 cisco 2960
1. I have set up a plethora of different DNS servers, from my WOWway ISP, to 8.8.8.8, to Open DNS, to almost anything I could think of to try, I can ping URLs, so I don't think it's an issue with DNS. I think so line encapsulation might be incorrect, but I hard coded the bandwidth on 10 megs on both sides, synched the MTUs. and cannot figure out why I cannot get a consistent 5/5 successful packets.
( I'll post outputs below)
The odd thing is that I sometimes I am losing no packets on the same IP/hostname/URL sometimes I am losing a lot, there's no consistency.
Here are some examples:
1. Translating "www.google.com"...domain server (64.233.217.3) [OK]Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 64.53.251.49, timeout is 2 seconds: !.!. Success rate is 40 percent (2/5), round-trip min/avg/max = 16/16/16 ms   ||||||||||||||
2. Translating "twitter.com"...domain server (64.233.217.3) [OK]Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 199.16.156.198, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/36/44 ms
3. ping 8.8.8.8 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 24/26/28 ms
4. r1#ping www.espn.com
Translating "www.espn.com"...domain server (64.233.217.3) [OK]
Sending 5, 100-byte ICMP Echos to 199.181.133.5, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 56/58/60 ms
_____show run_______
r1#show run
Building configuration...
Current configuration : 3609 bytes
! Last configuration change at 06:13:42 UTC Thu Sep 15 2016 by donald
version 15.1
service password-encryption
hostname r1
boot-start-marker
boot-end-marker
enable secret 5 $1$D6te$ChB1UHly1vvieAuIQVCn.0
no aaa new-model
memory-size iomem 5
no dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.14.1 192.168.14.200
ip dhcp excluded-address 192.168.18.1 192.168.18.200
ip dhcp excluded-address 192.168.200.1 192.168.200.200
ip dhcp excluded-address 192.168.20.1 192.168.20.200
ip dhcp excluded-address 192.168.21.1 192.168.21.200
ip dhcp excluded-address 192.168.22.1 192.168.22.200
ip dhcp excluded-address 192.168.23.1 192.168.23.200
ip dhcp excluded-address 192.168.24.1 192.168.24.200
ip dhcp excluded-address 192.168.25.1 192.168.25.200
ip dhcp excluded-address 192.168.26.1 192.168.26.200
ip dhcp pool 192.168.14.0
network 192.168.14.0 255.255.255.0
default-router 192.168.14.1
dns-server 8.8.8.8 4.4.4.4
ip dhcp pool 192.168.18.0
network 192.168.18.0 255.255.255.0
default-router 192.168.18.1
ip dhcp pool 192.168.200.0
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
ip dhcp pool 192.168.20.0
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool 192.168.21.0
network 192.168.21.0 255.255.255.0
default-router 192.168.21.1
ip dhcp pool 192.168.22.0
network 192.168.22.0 255.255.255.0
default-router 192.168.22.1
ip dhcp pool 192.168.23.0
network 192.168.23.0 255.255.255.0
default-router 192.168.23.1
ip dhcp pool 192.168.24.0
network 192.168.24.0 255.255.255.0
default-router 192.168.24.1
ip dhcp pool 192.168.25.0
network 192.168.25.0 255.255.255.0
default-router 192.168.25.1
ip dhcp pool 192.168.26.0
network 192.168.26.0 255.255.255.0
default-router 192.168.26.1
ip cef
ip name-server 64.233.217.3
ip name-server 8.8.8.8
ip name-server 208.67.222.222
ip name-server 84.200.69.80
no ipv6 cef
license udi pid CISCO1841 sn FHK124524MC
username donald password 7 0212164E0616
redundancy
interface FastEthernet0/0
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
bandwidth 10000
ip address 192.168.8.2 255.255.255.0
speed auto
full-duplex
interface Serial0/0/0
no ip address
no fair-queue
interface Serial0/1/0
ip address 192.168.9.1 255.255.255.252
router eigrp 1
network 192.168.0.0 0.0.255.255
network 192.168.8.0
redistribute static
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 0.0.0.0 0.0.0.0 192.168.8.1
ip route 192.168.8.0 255.255.255.0 FastEthernet0/1
ip route 192.168.200.0 255.255.255.0 192.168.9.2
access-list 101 permit udp any any eq domain
access-list 101 permit udp any eq domain any
snmp-server group GROUP1 v3 priv read ALL-ACCESS
snmp-server view ALL-ACCESS iso included
snmp-server view INT-ACCESS ifEntry included
control-plane
line con 0
password 7 1301181C0A0000
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
end
______show INT fa 0/1_______
#show int fa 0/1
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 0021.a028.d0d1 (bia 0021.a028.d0d1)
Internet address is 192.168.8.2/24
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3000 bits/sec, 3 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
22861 packets input, 3140949 bytes
Received 5019 broadcasts (0 IP multicasts)
9 runts, 0 giants, 0 throttles
9 input errors, 9 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
24853 packets output, 2569448 bytes, 0 underruns
1 output errors, 27 collisions, 30 interface resets
18 unknown protocol drops
0 babbles, 1 late collision, 0 deferred
0 lost carrier, 0 no carrier
Router board Interface GUI page connected to Ra Fa 0/1:
General
Name ether3
Type Ethernet
MTU 1500
L2 MTU
2000
Max L2 MTU 4074
MAC Address 6C:3B:6B:3F:01:AB
ARP
Master Port
Bandwidth (Rx/Tx) /
Switch switch1
Ethernet
Auto Negotiation not checked, tried both
Tx Flow Control
Rx Flow Control
Speed 10Mbps100Mbps1Gbps10Gbps | 10 megs
Full Duplex
Overall Stats
Tx/Rx Bytes
157120580/14201049
Tx/Rx 64
28951/61591
Tx/Rx 65-127
10398/19586
Tx/Rx 128-255
11115/3452
Tx/Rx 256-511
3307/1537
Tx/Rx 512-1023
3698/9937
Tx/Rx 1024-1518
100371/871
Tx/Rx 1519-max
0/0
Tx/Rx Too Long
0/0
Rx Stats
Rx Broadcast
852
Rx Pause
Rx Multicast
5372
Rx FCS Error
Rx Align Error
Rx Too Short
Rx Fragment
Rx Overflow
Tx Stats
Tx Broadcast
2103
Tx Pause
Tx Multicast
16847
Tx Underrun
Tx Collision
Tx Excessive Collision
Tx Multiple Collision
Tx Single Collision
Tx Excessive Deferred
Tx Deferred
Tx Late Collision
Status
Last Link Down Time Sep/15/2016 01:27:03
Last Link Up Time Sep/15/2016 01:27:05
Link Downs 8
Auto Negotiation disabled
Rate 10Mbps
Full Duplex
Advertising
10M half 10M full
100M half 100M full
1000M half 1000M full
Link Partner Advertising
10M half 10M full
100M half 100M full
Traffic
Tx/Rx Rate 1696 bps / 0 bps
Tx/Rx Packet Rate 1 p/s / 0 p/s
FP Tx/Rx Rate 0 bps / 0 bps
FP Tx/Rx Packet Rate 0 p/s / 0 p/s
Tx/Rx Bytes 149.8 MiB / 13.5 MiB
Tx/Rx Packets 157 840 / 96 974
Tx/Rx Drops 0 / 0
Tx/Rx Errors 0 / 0
I would love to hear your opinions, thanks.
Best Regards,
Sean Keltsch
seankeltsch
Hmmmm, no ideas at all? Am I trying to fit a square peg in a round hole?
NM I figured it out, I had two static routes point to my ISP router, one with exit int and one with next hop IP, I killed the exit int one, works, like a charm now!. YAY!
Sean,
good to know that you figured it out. I was initially thinking that the packet loss was not even caused by something in YOUR network, but by intermediate devices on the public network, where ICMP traffic is usually given low priority.
