PHY reset timed out in C1111-8P
Junak
Package header rev 3 structure detected
IsoSize = 500563968
Performing Integrity Check ...
Performing Signature Verification ...
RSA Signed RELEASE Image Signature Verification Successful
Image validated
PHY reset timed out
PHY reset timed out
Rom image verified correctly
System Bootstrap, Version 17.6.1, RELEASE SOFTWARE
Copyright (c) 1994-2021 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: Unrecoverable Error
C1111-8P platform with 4194304 Kbytes of main memory
media drive usb0: not present
autoboot: boot failed, restarting...
Resetting .......
PHY reset timed out
PHY reset timed out
Last reset cause: LocalSoft
no valid BOOT image found
Final autoboot attempt from default boot device...
Located pnp-tech-time
Unsupported package header version (-1347440721)
Located pnp-tech-discovery-summary
Unsupported package header version (542463043)
Located c1100-universalk9.16.12.04.SPA.bin
IsoSize = 500563968
Image validated
Please give me any solution.........................
Leo Laohoo
This router is a new "revision" and comes with ROMMON 17.6.1.
Do not use 16.12.4.  Instead use 16.12.8 (and newer).
FN72382 - C111x Hardware Shipments after May 2025, Require a Minimum Cisco IOS Software Version
Thank you for your reply. Already i am used Update Version so that why i am use this (16.12.8) version ,
Please check below....
PError writing session log (raw mode) to file: putty.log
HY reset timed out
PHY reset timed out
Last reset cause: PowerOn
Located c1100-universalk9.17.09.05a.SPA.bin
IsoSize = 634040320
Image validated
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Cupertino], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.9.5a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2024 by Cisco Systems, Inc.
Compiled Mon 12-Feb-24 11:59 by mcpre
This software version supports only Smart Licensing as the software licensing mechanism.
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
%FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk quota exceeded [free space is 878392 kB] - Please clean up files on bootflash .
cisco C1111-8P (1RU) processor with 1356275K/6147K bytes of memory.
Processor board ID FGL2544M01F
Router operating mode: Autonomous
1 Virtual Ethernet interface
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2945023K bytes of flash memory at bootflash:.
Press RETURN to get started!
*Feb 10 04:04:01.356: %CRYPTO-5-SELF_TEST_START: Crypto algorithms release (Rel5a)
begin self-test
*Feb 10 04:04:02.031: %CRYPTO-5-SELF_TEST_END: Crypto algoritms self-test completed successfully
All tests passed.
*Feb 10 04:04:02.849: %ISR_THROUGHPUT-6-CRYPTO: Crypto level has been set to 50000 kbps
*Feb 10 04:04:05.018: %SMART_LIC-6-AGENT_ENABLED: Smart Agent for Licensing is enabled
*Feb 10 04:04:05.260: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowedESG-PM-ACL:[subsys-init] Init ESG-ACL subsystem starting
*Feb 10 04:04:08.056: ESG-PM-ACL:[subsys-init] Init ESG-ACL platform API reg
*Feb 10 04:04:08.056: ESG-PM-ACL:[subsys-init] Init ESG-ACL subsystem ended
*Feb 10 04:04:10.393: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Feb 10 04:04:10.776: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_ENFORCED: Cisco PSB security compliance is being enforced
*Feb 10 04:04:10.776: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by this platform for use of RSA Key Size
*Feb 10 04:04:11.232: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by Sysl og Traps for use of MD5
*Feb 10 04:04:11.232: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by Sysl og Traps for use of DES
*Feb 10 04:04:11.232: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by Sysl og Traps for use of 3DES
*Feb 10 04:04:11.835: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Feb 10 04:04:11.882: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Feb 10 04:04:11.886: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Feb 10 04:04:12.133: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by encr ypt proc for use of 3DES
*Feb 10 04:04:12.134: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by encr ypt proc for use of MD5
*Feb 10 04:04:12.134: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by encr ypt proc for use of DES
*Feb 10 04:04:12.234: %PNP-6-PNP_DISCOVERY_STARTED: PnP Discovery started
*Feb 10 04:02:56.317: %IOSXE-3-PLATFORM: R0/0: kernel: mdio_bus f212a200.mdio-mii: MDIO device at address 29 is missing.
*Feb 10 04:02:56.318: %IOSXE-3-PLATFORM: R0/0: kernel: mdio_bus f212a200.mdio-mii: MDIO device at address 28 is missing.
*Feb 10 04:02:57.081: %IOSXE-3-PLATFORM: R0/0: kernel: mvpp2x f2000000.mvpp2x_ethernet: port ID: 0 cannot connect to phy
*Feb 10 04:03:53.276: %BOOT-5-OPMODE_LOG: R0/0: binos: System booted in AUTONOMOUS mode
*Feb 10 04:04:12.634: RG Infra Trace: Failure to get trace slot
*Feb 10 04:04:12.660: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Feb 10 04:04:12.738: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 50000 kbps
*Feb 10 04:04:13.993: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Feb 10 04:04:13.994: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Feb 10 04:04:14.008: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Feb 10 04:04:14.415: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Feb 10 04:04:17.306: %SYS-7-NVRAM_INIT_WAIT_TIME: Waited 0 seconds for NVRAM to be available
*Feb 10 04:04:21.531: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3342636371 has been generated or imported by crypto co nfig
*Feb 10 04:04:21.542: %SYS-6-PRIVCFG_DECRYPT_SUCCESS: Successfully apply the private config file
*Feb 10 04:04:21.755: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*Feb 10 04:04:21.759: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TP-self-signed-3342636371 created succesfully
*Feb 10 04:04:22.016: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 10 04:04:22.131: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Feb 10 04:04:22.131: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/1, interfaces disabled
*Feb 10 04:04:22.151: %SPA_OIR-6-OFFLINECARD: SPA (C1111-2x1GE) offline in subslot 0/0
*Feb 10 04:04:22.188: %SPA_OIR-6-OFFLINECARD: SPA (C1111-ES-8) offline in subslot 0/1
*Feb 10 04:04:22.324: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Feb 10 04:04:22.324: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Feb 10 04:04:22.347: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Feb 10 04:04:22.347: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Feb 10 04:04:22.888: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Feb 10 04:04:22.888: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/1
*Feb 10 04:04:23.142: %SYS-5-RESTART: System restarted --
*Feb 10 04:04:23.184: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Feb 10 04:04:28.105: RG Infra Trace: Failure to get trace slot
*Feb 10 04:04:29.239: %PNP-6-PNP_BEST_UDI_UPDATE: Best UDI [PID:C1111-8P,VID:V01,SN:FGL2544M01F] identified via (entity-mibs)
*Feb 10 04:04:29.248: %PNP-6-PNP_CDP_UPDATE: Device UDI [PID:C1111-8P,VID:V01,SN:FGL2544M01F] identified for CDP
*Feb 10 04:04:29.250: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Feb 10 04:04:31.873: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI created succesfully
*Feb 10 04:04:31.960: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Feb 10 04:04:32.311: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI0 created succesfully
*Feb 10 04:04:32.317: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NT P, can be obtained.
*Feb 10 04:04:32.575: %SYS-5-CONFIG_P: Configured programmatically by process EPM CREATE DEFAULT CWA URL ACL from console as console
*Feb 10 04:04:37.066: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3342636371.server has been generated or imported by cr ypto-engine
*Feb 10 04:04:37.655: %SPA_OIR-6-ONLINECARD: SPA (C1111-2x1GE) online in subslot 0/0
*Feb 10 04:04:44.318: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:04:46.863: %PMAN-3-PROCHOLDDOWN: F0/0: qfp-ucode-tsn-le: The process qfp-ucode-tsn-le has been helddown (rc 139)
*Feb 10 04:04:47.480: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d0 21ba7f errmsg:FFFFB428F000+DC8 cpp_common_os:FFFFB587D000+1C940 cpp_common_os:FFFFB587D000+136AC cpp_drv_hal_genmc_ulord:FFFFAB304000 +3B7C cpp_drv_hal_genmc_ulord:FFFFAB304000+326C cpp_drv_cmn:FFFFB6816000+1B4E4 cpp_dmap:FFFFB6C22000+13E50 cpp_palci_svr_lib:FFFFB658F 000+4E74 evlib:FFFFB47BD000+8800 evlib:FFFFB47BD000+9258 cpp_common_os:FFFFB587D000+21830 cpp_common_os:FFFFB587D000+217B4 :AAAAB13
*Feb 10 04:04:47.533: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_ha_top_level_server: cpp_ha encountered an error -Traceback= 1#b52ffe8065c2b 9e60fb876347b0c5c74 errmsg:FFFF93EEF000+DC8 cpp_common_os:FFFF95A96000+1C940 cpp_common_os:FFFF95A96000+136AC cpp_drv_hal_genmc_ulord :FFFF8FF6B000+3B7C cpp_drv_hal_genmc_ulord:FFFF8FF6B000+326C cpp_drv_cmn:FFFF95656000+1B4E4 cpp_dmap:FFFF95A61000+13E50 :AAAADB467000+ 20B14 :AAAADB467000+12A34 evlib:FFFF9441D000+8800 evlib:FFFF9441D000+9258 cpp_common_os:FFFF95A96000+21830 cpp_common_os:FFFF95A960
*Feb 10 04:04:52.482: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d0 21ba7f errmsg:FFFFB428F000+DC8 cpp_common_os:FFFFB587D000+1C940 cpp_common_os:FFFFB587D000+136AC cpp_drv_hal_genmc_ulord:FFFFAB304000 +3B7C cpp_drv_hal_genmc_ulord:FFFFAB304000+326C cpp_drv_cmn:FFFFB6816000+1B4E4 cpp_dmap:FFFFB6C22000+13E50 cpp_palci_svr_lib:FFFFB658F 000+4E74 evlib:FFFFB47BD000+8800 evlib:FFFFB47BD000+9258 cpp_common_os:FFFFB587D000+21830 cpp_common_os:FFFFB587D000+217B4 :AAAAB13
*Feb 10 04:04:54.146: spa in 0/1, still in booting
*Feb 10 04:04:54.318: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:04:57.534: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_ha_top_level_server: cpp_ha encountered an error -Traceback= 1#b52ffe8065c2b 9e60fb876347b0c5c74 errmsg:FFFF93EEF000+DC8 cpp_common_os:FFFF95A96000+1C940 cpp_common_os:FFFF95A96000+136AC cpp_drv_hal_genmc_ulord :FFFF8FF6B000+3B7C cpp_drv_hal_genmc_ulord:FFFF8FF6B000+326C cpp_drv_cmn:FFFF95656000+1B4E4 cpp_dmap:FFFF95A61000+13E50 :AAAADB467000+ 20B14 :AAAADB467000+12A34 evlib:FFFF9441D000+8800 evlib:FFFF9441D000+9258 cpp_common_os:FFFF95A96000+21830 cpp_common_os:FFFF95A960
*Feb 10 04:04:57.543: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d0 21ba7f errmsg:FFFFB428F000+DC8 cpp_common_os:FFFFB587D000+1C940 cpp_common_os:FFFFB587D000+136AC cpp_drv_hal_genmc_ulord:FFFFAB304000 +3B7C cpp_drv_hal_genmc_ulord:FFFFAB304000+326C cpp_drv_cmn:FFFFB6816000+1B4E4 cpp_dmap:FFFFB6C22000+13C8C cpp_punt_inject_svr_lib:FFF FB71EC000+CAD0 cpp_punt_inject_svr_lib:FFFFB71EC000+1A188 cpp_punt_inject_svr_lib:FFFFB71EC000+1E27C cpp_punt_inject_svr_msg_lib:FF
*Feb 10 04:04:58.313: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:02.307: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:02.890: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_ha_top_level_server: cpp_ha encountered an error -Traceback= 1#b52ffe8065c2b 9e60fb876347b0c5c74 errmsg:FFFF93EEF000+DC8 cpp_common_os:FFFF95A96000+1C940 cpp_common_os:FFFF95A96000+136AC cpp_drv_hal_genmc_ulord :FFFF8FF6B000+3B7C cpp_drv_cmn:FFFF95656000+1B4E4 cpp_dmap:FFFF95A61000+13E50 cpp_dp_util_ha:FFFF95471000+18AC :AAAADB467000+1EA78 :AA AADB467000+1E798 cpp_common_os:FFFF95A96000+236AC evlib:FFFF9441D000+88D0 evlib:FFFF9441D000+9258 cpp_common_os:FFFF95A96000+21830
*Feb 10 04:05:02.894: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: fman_fp_image: fman_fp encountered an error -Traceback= 1#a993b944bff71172b3f6bb 950171ae82 errmsg:FFFF90FD1000+DC8 cpp_common_os:FFFF981F2000+1C940 cpp_client_ha:FFFF97D60000+1F1C cpp_common_os:FFFF981F2000+236AC evlib:FFFF87EBA000+88D0 evlib:FFFF87EBA000+9258 :AAAACD293000+8C8D60 :AAAACD293000+8C8CE0 :AAAACD293000+7A28C0 :AAAACD293000+A1932C :A AAACD293000+A17B9C c:FFFF865C3000+249FC :AAAACD293000+2625F8
*Feb 10 04:05:03.484: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d0 21ba7f errmsg:FFFFB428F000+DC8 cpp_common_os:FFFFB587D000+1C940 cpp_common_os:FFFFB587D000+136AC cpp_drv_hal_genmc_ulord:FFFFAB304000 +3B7C cpp_drv_hal_genmc_ulord:FFFFAB304000+326C cpp_drv_cmn:FFFFB6816000+1B4E4 cpp_dmap:FFFFB6C22000+13E50 cpp_palci_svr_lib:FFFFB658F 000+4E74 evlib:FFFFB47BD000+8800 evlib:FFFFB47BD000+9258 cpp_common_os:FFFFB587D000+21830 cpp_common_os:FFFFB587D000+217B4 :AAAAB13
*Feb 10 04:05:04.875: %PMAN-0-PROCFAILCRIT: F0/0: pvp: A critical process qfp_ucode_tsn_le has failed (rc 139)
*Feb 10 04:05:06.177: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Feb 10 04:05:06.239: %IOSXE-6-PLATFORM: R0/0: cpp_sp: Shutting down CPP MDM while client(s) still connected
*Feb 10 04:05:06.401: %IOSXE-6-PLATFORM: R0/0: cpp_cp: Shutting down CPP MDM while client(s) still connected
*Feb 10 04:05:07.914: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: Critical process qfp_ucode_tsn_le fault on fp_0_0 (rc =139)
*Feb 10 04:05:10.310: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:12.326: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:12.980: %CMRP-5-CHASSIS_MONITOR_BOOT_TIME_PRINT: R0/0: cmand: Card 0 took 61 secs to boot
*Feb 10 04:05:24.147: spa in 0/1, still in booting
*Feb 10 04:05:26.326: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:28.309: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:30.321: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:31.322: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:35.314: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:36.317: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:38.998: %EVENTLIB-3-CPUHOG: C0/1: ngiolite: undefined: 1021ms, Traceback=1#82d9b0e2f579f0177a0101286ed658cf ld-linux-aa rch64:FFFFA34C7000+34648 c:FFFFA009E000+C9650 C1111-ES-8:FFFF9F79C000+2C274 dsdtapi:FFFF9F6F9000+E304 dsdtapi:FFFF9F6F9000+DF30 dsdtap i:FFFF9F6F9000+E8B8 dsdtapi:FFFF9F6F9000+22D80 C1111-ES-8:FFFF9F79C000+1EFF8 C1111-ES-8:FFFF9F79C000+FAF4 :AAAAE3C8A000+D1AC evlib:FFF FA3489000+8800
*Feb 10 04:05:39.484: %SPA_OIR-6-ONLINECARD: SPA (C1111-ES-8) online in subslot 0/1
*Feb 10 04:05:40.326: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:44.313: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:46.321: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:47.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:54.154: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
*Feb 10 04:05:54.313: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:55.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:05:56.322: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:05:56.444: %SMART_LIC-6-REPORTING_REQUIRED: A Usage report acknowledgement will be required in 363 days.
*Feb 10 04:06:00.317: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:06.313: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:08.322: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:15.320: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:17.318: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:20.319: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:24.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:29.319: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:30.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:32.319: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:33.317: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:37.313: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:39.317: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:41.318: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:44.317: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:49.314: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:06:52.474: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : Unable to resolve server hostname/domain name
*Feb 10 04:06:53.317: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
*Feb 10 04:06:58.309: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:06:59.311: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
Router>
Router>
*Feb 10 04:07:00.320: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:07:01.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEt
Router#
Router#
*Feb 10 04:07:55.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:07:57.318: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:08:00.318: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:08:03.309: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:08:09.998: %SERVICES-2-NORESOLVE_LOCAL: F0/0: btman: Error resolving local FRU: Invalid argument
*Feb 10 04:08:10.003: %SERVICES-3-INVALID_CHASFS: F0/0: btman: Thread 0xffffad013010 has no global chasfs context
*Feb 10 04:08:10.317: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:08:11.322: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:08:11.807: %PMAN-3-PROCFAIL: R0/0: cmand: The process cmand has failed (rc 139)PHY reset timed out
PHY reset timed out
IsoSize = 634040320
Image validated
Cisco Systems, Inc.
Software feature.
%FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk quota exceeded [free space is 851052 kB] - Please clean up files on bootflash.
*Feb 10 04:11:04.428: %CRYPTO-5-SELF_TEST_START: Crypto algorithms release (Rel5a)
begin self-test
*Feb 10 04:11:05.113: %CRYPTO-5-SELF_TEST_END: Crypto algoritms self-test completed successfully
All tests passed.
*Feb 10 04:11:05.926: %ISR_THROUGHPUT-6-CRYPTO: Crypto level has been set to 50000 kbps
*Feb 10 04:11:08.079: %SMART_LIC-6-AGENT_ENABLED: Smart Agent for Licensing is enabled
*Feb 10 04:11:08.314: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowedESG-PM-ACL:[subsys-init] Init ESG-ACL subsystem starting
*Feb 10 04:11:11.116: ESG-PM-ACL:[subsys-init] Init ESG-ACL platform API reg
*Feb 10 04:11:11.117: ESG-PM-ACL:[subsys-init] Init ESG-ACL subsystem ended
*Feb 10 04:11:13.496: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Feb 10 04:11:13.849: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_ENFORCED: Cisco PSB security compliance is being enforced
*Feb 10 04:11:13.849: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by this platform for use of RSA Key Size
*Feb 10 04:11:14.411: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by Syslog Traps for use of MD5
*Feb 10 04:11:14.411: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by Syslog Traps for use of DES
*Feb 10 04:11:14.411: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by Syslog Traps for use of 3DES
*Feb 10 04:11:15.014: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Feb 10 04:11:15.076: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Feb 10 04:11:15.077: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Feb 10 04:11:15.258: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by encrypt proc for use of 3DES
*Feb 10 04:11:15.259: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by encrypt proc for use of MD5
*Feb 10 04:11:15.259: %CRYPTO_ENGINE-5-CSDL_COMPLIANCE_EXCEPTION_ADDED: Cisco PSB security compliance exception has been added by encrypt proc for use of DES
*Feb 10 04:11:15.366: %PNP-6-PNP_DISCOVERY_STARTED: PnP Discovery started
*Feb 10 04:10:00.286: %IOSXE-3-PLATFORM: R0/0: kernel: mdio_bus f212a200.mdio-mii: MDIO device at address 29 is missing.
*Feb 10 04:10:00.287: %IOSXE-3-PLATFORM: R0/0: kernel: mdio_bus f212a200.mdio-mii: MDIO device at address 28 is missing.
*Feb 10 04:10:01.094: %IOSXE-3-PLATFORM: R0/0: kernel: mvpp2x f2000000.mvpp2x_ethernet: port ID: 0 cannot connect to phy
*Feb 10 04:10:55.960: %BOOT-5-OPMODE_LOG: R0/0: binos: System booted in AUTONOMOUS mode
*Feb 10 04:11:16.024: RG Infra Trace: Failure to get trace slot
*Feb 10 04:11:16.034: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Feb 10 04:11:16.047: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Feb 10 04:11:16.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Feb 10 04:11:16.092: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Feb 10 04:11:15.796: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 50000 kbps
*Feb 10 04:11:17.777: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Feb 10 04:11:20.553: %SYS-7-NVRAM_INIT_WAIT_TIME: Waited 0 seconds for NVRAM to be available
*Feb 10 04:11:24.919: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3342636371 has been generated or imported by crypto config
*Feb 10 04:11:24.929: %SYS-6-PRIVCFG_DECRYPT_SUCCESS: Successfully apply the private config file
*Feb 10 04:11:25.120: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*Feb 10 04:11:25.124: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TP-self-signed-3342636371 created succesfully
*Feb 10 04:11:25.509: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 10 04:11:25.541: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Feb 10 04:11:25.541: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/1, interfaces disabled
*Feb 10 04:11:25.567: %SPA_OIR-6-OFFLINECARD: SPA (C1111-2x1GE) offline in subslot 0/0
*Feb 10 04:11:25.590: %SPA_OIR-6-OFFLINECARD: SPA (C1111-ES-8) offline in subslot 0/1
*Feb 10 04:11:25.701: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Feb 10 04:11:25.701: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Feb 10 04:11:25.722: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Feb 10 04:11:25.723: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Feb 10 04:11:26.303: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Feb 10 04:11:26.304: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/1
*Feb 10 04:11:26.729: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Feb 10 04:11:27.449: %SYS-5-RESTART: System restarted --
*Feb 10 04:11:30.138: RG Infra Trace: Failure to get trace slot
*Feb 10 04:11:31.610: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-3342636371.server has been generated or imported by crypto-engine
*Feb 10 04:11:33.743: %PNP-6-PNP_BEST_UDI_UPDATE: Best UDI [PID:C1111-8P,VID:V01,SN:FGL2544M01F] identified via (entity-mibs)
*Feb 10 04:11:33.743: %PNP-6-PNP_CDP_UPDATE: Device UDI [PID:C1111-8P,VID:V01,SN:FGL2544M01F] identified for CDP
*Feb 10 04:11:33.744: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Feb 10 04:11:34.807: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI created succesfully
*Feb 10 04:11:34.937: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Feb 10 04:11:35.325: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI0 created succesfully
*Feb 10 04:11:35.338: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
*Feb 10 04:11:35.946: %SYS-5-CONFIG_P: Configured programmatically by process EPM CREATE DEFAULT CWA URL ACL from console as console
*Feb 10 04:11:38.931: %SPA_OIR-6-ONLINECARD: SPA (C1111-2x1GE) online in subslot 0/0
*Feb 10 04:11:40.853: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:11:40.890: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Feb 10 04:11:45.626: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:11:48.623: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:11:48.799: %PMAN-3-PROCHOLDDOWN: F0/0: qfp-ucode-tsn-le: The process qfp-ucode-tsn-le has been helddown (rc 139)
*Feb 10 04:11:49.675: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_ha_top_level_server: cpp_ha encountered an error -Traceback= 1#b52ffe8065c2b9e60fb876347b0c5c74 errmsg:FFFF910E3000+DC8 cpp_common_os:FFFF92C8A000+1C940 cpp_common_os:FFFF92C8A000+136AC cpp_drv_hal_genmc_ulord:FFFF8D15F000+3B7C cpp_drv_hal_genmc_ulord:FFFF8D15F000+326C cpp_drv_cmn:FFFF9284A000+1B4E4 cpp_dmap:FFFF92C55000+13E50 :AAAAB373B000+20B14 :AAAAB373B000+12A34 evlib:FFFF91611000+8800 evlib:FFFF91611000+9258 cpp_common_os:FFFF92C8A000+21830 cpp_common_os:FFFF92C8A0
*Feb 10 04:11:49.678: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d021ba7f errmsg:FFFFB50BE000+DC8 cpp_common_os:FFFFB66AC000+1C940 cpp_common_os:FFFFB66AC000+136AC cpp_drv_hal_genmc_ulord:FFFFAC133000+3B7C cpp_drv_hal_genmc_ulord:FFFFAC133000+326C cpp_drv_cmn:FFFFB7645000+1B4E4 cpp_dmap:FFFFB7A51000+13E50 cpp_palci_svr_lib:FFFFB73BE000+4E74 evlib:FFFFB55EC000+8800 evlib:FFFFB55EC000+9258 cpp_common_os:FFFFB66AC000+21830 cpp_common_os:FFFFB66AC000+217B4 :AAAAC0C
*Feb 10 04:11:54.679: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d021ba7f errmsg:FFFFB50BE000+DC8 cpp_common_os:FFFFB66AC000+1C940 cpp_common_os:FFFFB66AC000+136AC cpp_drv_hal_genmc_ulord:FFFFAC133000+3B7C cpp_drv_hal_genmc_ulord:FFFFAC133000+326C cpp_drv_cmn:FFFFB7645000+1B4E4 cpp_dmap:FFFFB7A51000+13E50 cpp_palci_svr_lib:FFFFB73BE000+4E74 evlib:FFFFB55EC000+8800 evlib:FFFFB55EC000+9258 cpp_common_os:FFFFB66AC000+21830 cpp_common_os:FFFFB66AC000+217B4 :AAAAC0C
*Feb 10 04:11:58.626: spa in 0/1, still in booting
*Feb 10 04:11:59.674: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_ha_top_level_server: cpp_ha encountered an error -Traceback= 1#b52ffe8065c2b9e60fb876347b0c5c74 errmsg:FFFF910E3000+DC8 cpp_common_os:FFFF92C8A000+1C940 cpp_common_os:FFFF92C8A000+136AC cpp_drv_hal_genmc_ulord:FFFF8D15F000+3B7C cpp_drv_hal_genmc_ulord:FFFF8D15F000+326C cpp_drv_cmn:FFFF9284A000+1B4E4 cpp_dmap:FFFF92C55000+13E50 :AAAAB373B000+20B14 :AAAAB373B000+12A34 evlib:FFFF91611000+8800 evlib:FFFF91611000+9258 cpp_common_os:FFFF92C8A000+21830 cpp_common_os:FFFF92C8A0
*Feb 10 04:11:59.681: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d021ba7f errmsg:FFFFB50BE000+DC8 cpp_common_os:FFFFB66AC000+1C940 cpp_common_os:FFFFB66AC000+136AC cpp_drv_hal_genmc_ulord:FFFFAC133000+3B7C cpp_drv_hal_genmc_ulord:FFFFAC133000+326C cpp_drv_cmn:FFFFB7645000+1B4E4 cpp_dmap:FFFFB7A51000+13E50 cpp_palci_svr_lib:FFFFB73BE000+4E74 evlib:FFFFB55EC000+8800 evlib:FFFFB55EC000+9258 cpp_common_os:FFFFB66AC000+21830 cpp_common_os:FFFFB66AC000+217B4 :AAAAC0C
*Feb 10 04:12:04.687: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_cp_svr: cpp_cp encountered an error -Traceback= 1#8d66b6a164a770777a927ad8d021ba7f errmsg:FFFFB50BE000+DC8 cpp_common_os:FFFFB66AC000+1C940 cpp_common_os:FFFFB66AC000+136AC cpp_drv_hal_genmc_ulord:FFFFAC133000+3B7C cpp_drv_hal_genmc_ulord:FFFFAC133000+326C cpp_drv_cmn:FFFFB7645000+1B4E4 cpp_dmap:FFFFB7A51000+13E50 cpp_palci_svr_lib:FFFFB73BE000+4E74 evlib:FFFFB55EC000+8800 evlib:FFFFB55EC000+9258 cpp_common_os:FFFFB66AC000+21830 cpp_common_os:FFFFB66AC000+217B4 :AAAAC0C
*Feb 10 04:12:04.886: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: cpp_ha_top_level_server: cpp_ha encountered an error -Traceback= 1#b52ffe8065c2b9e60fb876347b0c5c74 errmsg:FFFF910E3000+DC8 cpp_common_os:FFFF92C8A000+1C940 cpp_common_os:FFFF92C8A000+136AC cpp_drv_hal_genmc_ulord:FFFF8D15F000+3B7C cpp_drv_cmn:FFFF9284A000+1B4E4 cpp_dmap:FFFF92C55000+13E50 cpp_dp_util_ha:FFFF92665000+18AC :AAAAB373B000+1EA78 :AAAAB373B000+1E798 cpp_common_os:FFFF92C8A000+236AC evlib:FFFF91611000+88D0 evlib:FFFF91611000+9258 cpp_common_os:FFFF92C8A000+21830
*Feb 10 04:12:04.888: %CPPOSLIB-3-ERROR_NOTIFY: F0/0: fman_fp_image: fman_fp encountered an error -Traceback= 1#a993b944bff71172b3f6bb950171ae82 errmsg:FFFFB5A82000+DC8 cpp_common_os:FFFFBCCA3000+1C940 cpp_client_ha:FFFFBC811000+1F1C cpp_common_os:FFFFBCCA3000+236AC evlib:FFFFAC96B000+88D0 evlib:FFFFAC96B000+9258 :AAAAD3113000+8C8D60 :AAAAD3113000+8C8CE0 :AAAAD3113000+7A28C0 :AAAAD3113000+A1932C :AAAAD3113000+A17B9C c:FFFFAB074000+249FC :AAAAD3113000+2625F8
*Feb 10 04:12:06.796: %PMAN-0-PROCFAILCRIT: F0/0: pvp: A critical process qfp_ucode_tsn_le has failed (rc 139)
*Feb 10 04:12:07.931: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Feb 10 04:12:07.980: %IOSXE-6-PLATFORM: R0/0: cpp_sp: Shutting down CPP MDM while client(s) still connected
*Feb 10 04:12:08.082: %IOSXE-6-PLATFORM: R0/0: cpp_cp: Shutting down CPP MDM while client(s) still connected
*Feb 10 04:12:09.661: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: Critical process qfp_ucode_tsn_le fault on fp_0_0 (rc=139)
*Feb 10 04:12:11.638: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:12:12.637: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:12:16.049: %CMRP-5-CHASSIS_MONITOR_BOOT_TIME_PRINT: R0/0: cmand: Card 0 took 61 secs to boot
*Feb 10 04:12:17.627: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:12:22.634: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:12:28.626: spa in 0/1, still in booting
*Feb 10 04:12:29.642: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:12:31.639: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:12:35.645: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:12:36.646: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:12:41.037: %SPA_OIR-6-ONLINECARD: SPA (C1111-ES-8) online in subslot 0/1
*Feb 10 04:12:43.625: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:12:44.626: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Feb 10 04:12:50.637: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Feb 10 04:12:51.638: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
Router>
Router>
Router>
Router>
Router>
*Feb 10 04:12:55.629: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
Router>
Router>
Router>
Router>
Router>
*Feb 10 04:12:56.634: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
I am seeing the router successfully booting 17.9.5a.
I do not see the router making any attempts to boot 16.12.8 (or later).
