PIM Bidir in 6509
Antonio Macia
Level 3
Level 3
I'm trying to configure PIM Bidir on a Cat6509 running the s2t54-adventerprisek9-mz.SPA.151-2.SY8.bin image, but I don't see the bidir option when configuring the rp address. Looking at the Cisco Feature Navigator, this image supports Bidirectional PIM. Why the option is not available?
6509(config)#ip pim rp-address 1.1.1.1 ?
<1-99> Access-list reference for group
<1300-1999> Access-list reference for group (expanded range)
WORD IP Named Standard Access list
override Overrides dynamically learnt RP mappings
<cr>
6509(config)#ip pim rp-address 1.1.1.1 1 ?
<cr>
Regards.
cscochetan
 Try the command  ' ip pim bidir-enable ' and give feedback
  15.2(1) SY6 is latest IOS for  Catalyst 6509 switch
Thanks cscochetan,
I was thinking the same but wanted it to double-check with someone that have configured it before.
I'm now preparing the configurations for the change because this is a production system and I need to validate the commands prior to the maintenance window.
